Squeeky suspension
Old Apr 8, 2011 | 03:56 AM
niterider64's Avatar
niterider64
Default Squeeky suspension
I have a 2000 with a z51 susp. with 82k miles but it sounds like an old ford that has 250k of limerock road use. Any kind of bump or flex of the suspension creates a lot of squeeking, it mainly sounds like it is coming from the front. Is this a common problem, is there a certain bushing that goes bad, can they be lubricated with silicone or some other lub? Thanks for any input.
Old Apr 8, 2011 | 10:31 AM
David426's Avatar
David426
Its more than likely the front sway bar bushings and maybe the rear sway bar bushings.. Yes. this is a common problem and an easy fix.. I used Lithium grease to solve the problem on my 99 C5.. There are 2 rubber bushings on the front and 2 on the back.. Unbolt the bushings and apply grease liberally to the inside of the bushing.. 15 minute job.. No more squeaky creaky
Old Apr 8, 2011 | 10:39 PM
niterider64
Default squeeky suspension
Thanks for the input. I have read a few other threads and one guy replaced the shocks and that finally fixed it. I think I'll start with the cheep stuff first, thanks again for the help.
To Squeeky suspension
