ABS Traction control issue
Old Apr 9, 2011 | 04:06 PM
harrell3us's Avatar
harrell3us
Default ABS Traction control issue
Codes:
P1571 - Traction Control Torque Request Circuit
C1243 - BPMV Pump Motor Stalled
B2527 - Horn Relay Circuit (actually unplugged fuse due to horn blowing at random)
Now what do I do? Are these difficult to fix on my own? Help, please!
Old Apr 11, 2011 | 08:05 PM
jswizz's Avatar
jswizz
my car is doing the same thing. I understand that are no BPMV's out there what year is your car mine is a1997.
My lights go out when temp goes up and the car warms up.
What does yours do.
Take alook at this
.http://forums.corvetteforum.com/c5-t...-the-bpmv.html
this will help you.
Good luck
Old Apr 11, 2011 | 08:11 PM
harrell3us's Avatar
harrell3us
It is a 1997. Amazing they always do the same things. But I do not have a temp prom.
Old Apr 11, 2011 | 08:21 PM
harrell3us's Avatar
harrell3us
I do believe this will help tremendously. Thank you very much. Chevrolet dealership said I was probably looking at over a thousand to fix.
Old Apr 11, 2011 | 08:29 PM
jswizz's Avatar
jswizz
I was told there're no BPMV out thereand the last list price is $ 2,000.00
Old Apr 11, 2011 | 08:53 PM
Bill Dearborn's Avatar
Bill Dearborn
P1571 is a persistent code on 97s and should be ignored unless there are traction control issues and all other codes have been solved. GM released a TSB on this. The TSB has been posted on the forum several times over the last 10 years.
I doubt you will be able to find replacement EBCMs and BPMVs for this car as the rear mounted EBCM/BPMVs only lasted through about half the 98 model year. Still you can check voltages and grounds and wiring to make sure they are in good condition. Well over 50% of all electronic issues are due to problems in those three areas so it doesn't hurt to check them. Here is the diagnostic for DTC C1243. Follow the diagnostic and do the things you can do with a DVM.
Bill
To ABS Traction control issue
