car is coding p0151
DTC P0131 or P0151
Circuit Description
The powertrain control module (PCM) supplies a voltage of approximately 450 mV between the heated oxygen sensor (HO2S) high and low signal circuits. The heated oxygen (HO2S) sensor varies the voltage from approximately 1,000 mV if the exhaust is rich, to approximately 10 mV if the exhaust is lean.
The PCM monitors and stores the HO2S voltage information. The PCM evaluates the HO2S voltage samples in order to determine the amount of time during which the HO2S voltage was out of range. The PCM compares the stored HO2S voltage samples taken within each sample period, and determines if the majority of the samples are out of the operating range.
The PCM monitors the HO2S voltage for being fixed below a predetermined voltage. If the PCM detects that the voltage is less than the predetermined voltage, a DTC sets.
Conditions for Running the DTC
DTCs P0101, P0102, P0103, P0106, P0107, P0108, P0112, P0113, P0116, P0117, P0118, P0200, P0300, P0410, P0440, P0442, P0446, P0452, P0453, P1120, P1125, P1220, P1221, P1258, P1415, P1416, P1441, P1514, P1515, P1516, P1517, or P1518 are not set.
The ignition 1 signal is between 9-18 volts.
The fuel tank level remaining is more than 10 percent.
The loop status is Closed.
Intrusive tests are not in progress.
Scan tool output controls are not active.
Lean Test Enable
The air fuel ratio is between 14.5:1 and 14.7:1
The throttle position (TP) indicated angle is between 3-70 percent more than the value observed at idle.
Power Enrichment Test Enable
Power Enrichment is active.
The above condition is met for 1 second.
Conditions for Setting the DTC
Lean Test
The HO2S voltage is less than 200 mV for 165 seconds.
The HO2S voltage is less than 360 mV for 10 seconds.
Action Taken When the DTC Sets
The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
The control module commands Open Loop.
Conditions for Clearing the MIL/DTC
The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
Important
Before you service the PCM and throttle actuator control (TAC) module, remove any debris from the module connector surfaces. When you diagnose or replace the modules, inspect the module connector gaskets. Ensure that the gaskets are correctly installed. The gaskets prevent contaminate intrusion into the PCM/TAC modules.
Use the J 35616-A Connector Test Adapter Kit for any test that requires probing the PCM or probing a component harness connector. Using this kit prevents damage to the harness and component terminals. Refer to Using Connector Test Adapters in Wiring Systems.
The PCM sets this DTC when the vehicle runs out of fuel.
The sensor pigtail for the heated oxygen sensor (HO2S) wire may be contacting the exhaust manifold or contacting the exhaust system.
An oxygen supply inside the HO2S is necessary for proper operation. The HO2S wires provides the supply of oxygen. Inspect the HO2S wires and connections for breaks or for contamination. Refer to Wiring Repairs in Wiring Systems.
Inspect for an intermittent ground in the signal wire between the connector and the sensor.
Inspect for lean injectors. Perform the Injector Balance Test. Refer to Fuel Injector Balance Test with Tech 2 or Fuel Injector Balance Test with Special Tool .
Inspect for fuel contamination. Water near the in-tank fuel pump inlet can be delivered to the injectors. The water causes a lean exhaust, and can set a DTC. Refer to Alcohol/Contaminants-in-Fuel Diagnosis .
Inspect the fuel pressure. The system will be lean if the fuel pressure is low. Refer to Fuel System Diagnosis .
Inspect for exhaust leaks. An exhaust leak near the HO2S can cause a lean condition. Refer to Exhaust System Description in Engine Exhaust.
Inspect for vacuum leaks or for crankcase leaks that can cause a lean condition.
Inspect the HO2S.
For an intermittent condition, refer to Intermittent Conditions .
Test Description
The numbers below refer to the step numbers on the diagnostic table.
If the HO2S voltage is fixed well below 200 mV, this indicates a short to ground.
Using the Freeze Frame/Failure Records data may help to locate an intermittent condition. If you cannot duplicate the DTC, the information included in the Freeze Frame/Failure Records data can help to determine how many miles have occurred since the DTC set. The Fail Counter and Pass Counter can also help to determine the number of ignition cycles since the diagnostic reported a pass or a fail. Operate the vehicle within the same Freeze Frame conditions that the PCM recorded, including the RPM, the vehicle load, the vehicle speed, and the temperature. This procedure isolates when the DTC failed.
A disconnected sensor should indicate a bias voltage. If the voltage is low, inspect the HO2S high signal circuit for a short to ground.
Step
Action
Value(s)
Yes
No
Schematic Reference: Engine Controls Schematics
1
Did you perform the Diagnostic System Check-Engine Controls?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
2
Start and run the engine until normal operating temperature is reached.
With a scan tool, observe the HO2S voltage for the sensor that applies to this DTC.
Is the HO2S voltage less than the specified value?
200 mV
Go to Step 4
Go to Step 3
3
Observe the Freeze Frame/Failure Records data for this DTC.
Turn OFF the ignition for 30 seconds.
Start the engine.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text or as close to the Freeze Frame/Failure Records data that you observed.
Does the DTC fail this ignition?
Go to Step 4
Go to Diagnostic Aids
4
Turn OFF the ignition.
Disconnect the HO2S connector for the sensor that applies to this DTC.
Jumper the HO2S low signal circuit terminal on the engine harness side to a known good ground.
Turn ON the ignition, with the engine OFF.
Observe the HO2S voltage with a scan tool.
Is the HO2S voltage within the specified range?
350-550 mV
Go to Step 5
Go to Step 6
5
The HO2S may be detecting a lean exhaust condition. Check for the following conditions:
Water intrusion into the HO2S connector
Exhaust leak between the HO2S and the engine
Vacuum leaks
Incorrect fuel pressure
Lean fuel injectors
Inaccurate MAF sensor
Repair any of the above or similar engine conditions as necessary.
Did you find and correct the condition?
Go to Step 12
Go to Step 8
6
Disconnect the PCM connector that contains the HO2S high signal circuit. Refer to Powertrain Control Module (PCM) Replacement
Test the HO2S high signal circuit for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 12
Go to Step 7
7
Test the HO2S high signal circuit for a short to the HO2S Low signal circuit. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 12
Go to Step 9
8
Inspect for poor connections at the harness connector of the HO2S. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 12
Go to Step 10
9
Inspect for poor connections at the harness connector of the PCM. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 12
Go to Step 11
10
Replace the affected HO2S. Refer to Heated Oxygen Sensor (HO2S) Replacement Bank 1 Sensor 1 , or Heated Oxygen Sensor (HO2S) Replacement Bank 2 Sensor 1 .
Did you complete the replacement?
Go to Step 12
11
Replace the PCM. Refer to Powertrain Control Module (PCM) Replacement .
Go to Step 12
12
Use the scan tool in order to clear the DTCs.
Start the engine.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC run and pass?
Go to Step 13
Go to Step 2
13
With a scan tool, observe the stored information, Capture Info.
Does the scan tool display any DTCs that you have not diagnosed?
Go to Diagnostic Trouble Code (DTC) List
System OK
