airconditioning
Old Apr 10, 2011 | 02:01 PM
1BADL82's Avatar
1BADL82
Default airconditioning
I have a 98 conv. when i turn the air on drivers side and center vents blow hot air and the pass. side vent blows cold dont know whats going on.
THX
Old Apr 10, 2011 | 02:03 PM
jrose7004's Avatar
jrose7004
My 98 always did that when the freon needed charged. Do a search ,this problem has many many threads on it.
Old Apr 10, 2011 | 02:37 PM
1BADL82's Avatar
1BADL82
Thx, just had it charged, will do a search
Old Apr 10, 2011 | 03:07 PM
dmarkshark's Avatar
dmarkshark
First thing is to check your codes on the DIC, then report back, also note if the codes have a H or C after them (if you have any).
Old Apr 10, 2011 | 03:14 PM
1BADL82's Avatar
1BADL82
there are no codes I just noticed I hear a vaccum leak by the front pass side of the car by the front of the door or under the cowl
Old Apr 10, 2011 | 04:12 PM
dmarkshark's Avatar
dmarkshark
The electronic vacuum selonlid is under there. Just get under there and you will see it, maybe a loose hose or something. Also check and see if you can change where the air comes out, defrost, middle, floor. Hope this helps. But first, see if you can change the air flow locations, if they don't change then you know you have a vaccuum leak and will need to take a look under the passenger area.
Old Apr 10, 2011 | 06:05 PM
1BADL82's Avatar
1BADL82
Will check it out
THX
Old Apr 11, 2011 | 10:01 AM
rebelheart's Avatar
rebelheart
You prob have two problems.Repair the vacuum leak first,then fill the system to specs,it is probably slightly low on freon.
Old Mar 12, 2021 | 02:46 PM
v6turbo87's Avatar
v6turbo87
The vacuum signal is only used to control where the air comes out from. It has nothing to do with how cold the AC blows. When the vacuum is lost the air will blow out of the defrost vents and floor vent only.
Old Mar 12, 2021 | 09:23 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
10 year old thread !!
To airconditioning
