Running rough
Old Apr 11, 2011 | 07:26 PM
Drumbum675's Avatar
Drumbum675
Default Running rough
Car started running rough between 1700 and 2500 rpm. No codes, everything looks good under the hood. Plug wires are fairly new and dont seem to be loose????
Old Apr 14, 2011 | 04:30 AM
98c5lswon's Avatar
98c5lswon
did you check the spark plugs? When was the last fuel filter change?
Old Apr 14, 2011 | 06:54 PM
Drumbum675's Avatar
Drumbum675
plugs were replaced when I put on long tubes about 1.5 yrs ago. Not sure about fuel filter. I'm going to spray the maf and check the vacuum lines.
Old Apr 14, 2011 | 07:16 PM
lucky131969's Avatar
lucky131969
Codes?
Old Apr 15, 2011 | 08:59 PM
Drumbum675's Avatar
Drumbum675
no codes
Old Apr 16, 2011 | 08:11 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
PCV valve connection tube to the intake, is there any holes in it? Is the air-bridge set on the intake properly, especially on the bottom?
Old Apr 18, 2011 | 02:43 AM
Drumbum675's Avatar
Drumbum675
The air bridge came loose. I tightened it back up, but still have the problem.
Old Apr 18, 2011 | 07:44 AM
dgrant3830's Avatar
dgrant3830
Might pull the air bridge back off, extract the maf and spray it out with an electronic cleaner spray. Do not touch the element inside the maf. Just because the wires are fairly new doesn't mean one didn't go bad but before going there, need to look at other things, therefore not wasting money. How rough are we talking about? I mean, is it stumbling or just a slight miss? Does it happen while nailing the gas pedal to the floor or slowly accelerating?
Old Apr 18, 2011 | 11:59 AM
Outlawwed Z06's Avatar
Outlawwed Z06
did you just put a new tank of gas in it befor the problome occured?
Old Apr 18, 2011 | 11:17 PM
Drumbum675's Avatar
Drumbum675
sprayed the maf today. it was very dirty. It seems to have solved most of the problem, but still just a bit rough.
To Running rough
