my traction control button does not work
Old Apr 13, 2011 | 09:01 AM
tank99_999's Avatar
tank99_999
Default my traction control button does not work
i have a 2000 c5 frc , and when i push my traction control button it does nothing???? i took the fuse out and then it turned off but i want the button to work. is there ne whay to just keep it off or just fix it? replace button? help!! lol thanks
Old Apr 13, 2011 | 09:40 AM
lucky131969's Avatar
lucky131969
Is it plugged in?
Old Apr 13, 2011 | 06:48 PM
tank99_999's Avatar
tank99_999
Yes its plugged in lol
Old Apr 13, 2011 | 07:07 PM
lucky131969
Have you checked your codes? What fuse did you pull.....the switch provides a ground to the BCM. Have you checked for 12 volts and ground at the switch connector? Have you checked the resistance value across the switch itself?
Old Apr 14, 2011 | 12:12 AM
tank99_999's Avatar
tank99_999
it has no codes, i pulled the trac control fuse i think. i have not checked ne thing else i will tommarow thaks for your help
To my traction control button does not work
