Guess my numbers H/C/I
Old Apr 14, 2011 | 06:41 PM
DANZGLASS's Avatar
DANZGLASS
Default Guess my numbers H/C/I
Set My appointment for April 25th at Rpm motors in Santa Clarita. They are going to do my Head, Cam, Intake, Headers install and tune. I am starting this thread for fun since it's so close now!!
02 c5z06
Parts list
Flp Lontubes/cats/x-pipe
Slp Loudmouth catback
224-230 .588/.592 114 XER Going to run a 228/232 .585/.595 113LSA XER
Trick flow 220's TEA port work, milled to 59cc
Yella Terra 1.7
Spin Ported fast 92 with 96mm mouth and 96mm NW throttle body
Blackwing intake
Powerbond UD pulley
Monster stg 3 light flywheel
New oil Pump
New ls7 lifters/trays
Oil catch can
SVO 30's
ALL new Bolts and gaskets
I'm getting excited!
Will post the numbers when shes done and hopefully some vids If i can get them.
Just picked her up made 450/412
Old Apr 14, 2011 | 06:46 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Last one I saw with the same mods and a little bigger cam was 450-460RWHP
Old Apr 14, 2011 | 06:48 PM
DANZGLASS's Avatar
DANZGLASS
Magic number for me is 450 but i am hoping for some nice torque too.
Old Apr 25, 2011 | 09:17 PM
DANZGLASS's Avatar
DANZGLASS
After some thoughts on my combo I am thinking about getting a little more aggressive cam. There are two i'm looking at. 228/232 .585/.595 113LSA XER or 230/232 .595/.585 112+4LSA cam motion. What are your guys thoughts on this possible cam change? I have postponed the install for the time being.
Old Apr 25, 2011 | 09:55 PM
lucky131969's Avatar
lucky131969
Old Apr 26, 2011 | 09:26 AM
C5Longhorn's Avatar
C5Longhorn
Any updates?
Old Apr 26, 2011 | 10:02 AM
DANZGLASS's Avatar
DANZGLASS
changing the cam out as per my post. didn't have enough time to get it before my install so it got pushed back a couple weeks. Wanted a little more cam with a little more bite then -1* overlap. Going to set up most likely for the MAY 9th now.
Old Apr 26, 2011 | 12:08 PM
jd86L98's Avatar
jd86L98
Better choice with those heads.
Old Apr 26, 2011 | 03:02 PM
David426's Avatar
David426
Dyno numbers are very subjective... Its not like getting on a scale and coming up with an absolute number everytime... what dyno?? Mustang??. Dynojet??... SAE corrected or STD corrected numbers? Or uncorrected numbers with no smoothing factor? Who is the technician?? If the numbers are uncorrected, whats your Density Altitude?? Your numbers may vary by as much as 30rwhp depending on what your answers are to the above questions.. Different techs and different shops do things differently.. Thats why you see crazy variations day after day and post after post on this forum... Based on the above variables you should make between 440-470 rwhp
Old Apr 26, 2011 | 03:36 PM
Bluefire's Avatar
Bluefire
I say 435 rwhp 405 rwtq.
You're welcome.
Old Apr 26, 2011 | 05:25 PM
DANZGLASS's Avatar
DANZGLASS
You're welcome.
so 20 more then you with a six speed awesome heads and a ported fast setup. Damn i hope not! You are stock 243's ls6 intake and an auto and made 416.
Old Apr 26, 2011 | 05:27 PM
DANZGLASS's Avatar
DANZGLASS
charlie at Rpm motors in Valencia CA is doing the tune. They are installing also.
Old Apr 26, 2011 | 05:59 PM
legman's Avatar
legman
472-423....my guess
Should be pretty stout regardless of the final numbers.....
Old Apr 26, 2011 | 07:38 PM
zeevette's Avatar
zeevette
I had a very similar setup, with the addition of a Meziere EWP, and a hand ported 90/90 setup that did 483/432 SAE corrected on a Dynojet, and then promply ate the stock clutch. My cam was a Crane 228-232@112+5, and .600 lift. I had one of the very first hand finished 215 Trickflows that TEA produced.(61cc) They had to be rebuilt after the rockers wore furrows in the valve stems. I barely caught it in time, but they paid for all new parts, and shipping. I just had to do it all over in my garage again.
Old Apr 26, 2011 | 07:52 PM
DANZGLASS's Avatar
DANZGLASS
what rockers did that?
Old Apr 26, 2011 | 08:41 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
02 c5z06
Parts list
224-230 .588/.592 114 XER Going to run a Futral F13 230/232 .595/.585 112+4LSA
Yella Terra 1.7
Blackwing intake
Powerbond UD pulley
New oil Pump
Oil catch can
SVO 30's
very nice choice in parts...looks like youve been researching for a bit!
After some thoughts on my combo I am thinking about getting a little more aggressive cam. There are two i'm looking at. 228/232 .585/.595 113LSA XER What are your guys thoughts on this possible cam change? I have postponed the install for the time being.
I like that cam profile, that gets my vote! Although I would look into getting it in a different type other than XER.... less stress on your springs.
My guess would be 471rwhp / 427 RWT but with a nice overall power curve and very streetable!
Old Apr 26, 2011 | 09:29 PM
KorbenDallas's Avatar
KorbenDallas
I'll guess 440-465rwhp.
To Guess my numbers H/C/I
Old Apr 26, 2011 | 11:15 PM
ZZ06's Avatar
ZZ06
Originally Posted by Ikester
very nice choice in parts...looks like youve been researching for a bit! I like that cam profile, that gets my vote! Although I would look into getting it in a different type other than XER.... less stress on your springs.
My thoughts exactly! My guess with what you have ported would 463/420.
Old Apr 27, 2011 | 01:09 AM
zeevette's Avatar
zeevette
The stock ones. The early TF heads geometry was different than current, and you had to have extra long PRs, and roller rockers. TEA sent me a free set of Harland Sharps, and they've worked fine.
Old May 9, 2011 | 08:38 PM
DANZGLASS's Avatar
DANZGLASS
dropped her off this morning!
