I am sure this has been answered many times but I cant find the answer.
Check engine light on, can't pass smog. Code indicates knock sensor. I want to replace both.
I have seen to different locations under manifold or back of block. I believe them to be under the manifold. I am looking for instructions for intake manifold removal for an LS1 (1999 coupe).
Under the intake, 2 of them. Replace the plugs at the bottom, both sensors and the pigtail connecting them. Might want to relo the Oil sensor while you there.
