HVAC issue
Old Apr 16, 2011 | 02:11 AM
ckim34's Avatar
ckim34
Default HVAC issue
When I turn on my A/C the drivers side vents blow hot air but the passenger side gets cold air. Anyone have any idea what the problem is? Thanks
Old Apr 16, 2011 | 07:13 AM
Dream C5's Avatar
Dream C5
Pull codes and post sounds like bad ac actuator, if you dont have any codes may be low on freon. Re-indexing may work also do a search for instructions.
Old Apr 16, 2011 | 07:39 AM
seoulbrooks's Avatar
seoulbrooks
Common problem with C5. I would suggest before you do any tearing into actuators you have someone check the low/high pressures. Take it to someone that knows what they are doing and make sure the pressures are correct. There is a very good explanation here on the forum as to why the A/C does this. There are also good write-ups concerning the correct pressures at specific RPM/Temperture/humidity. The pressures have got to be correct or you will continue to have the problem. If the pressures are correct there could be a craked gear on the drivers actuator as suggested above. May or may not throw a code. Probably have a slow leak in the system. Good luck.....
Old Apr 16, 2011 | 08:04 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree with pulling the codes to start with. From there, you'll have a better idea.
Old Apr 16, 2011 | 09:49 PM
ckim34's Avatar
ckim34
time to take her to my mechanic. seeing as how my vette has over 170k and this is the first time Ive had a real problem with it i guess it was due! thanks for the info guys!
Old Apr 16, 2011 | 11:10 PM
jrose7004's Avatar
jrose7004
My 98 did that when it needed freon.
To HVAC issue
