C5 Convertible Top
Old Apr 18, 2011 | 02:02 AM
Donnasophia's Avatar
Donnasophia
Default C5 Convertible Top
I've had my white 1998 a few weeks and think I've messed up something. I pushed the hatch release button (that stores the top) behind the driver's seat, while the top was secured in the up position.
I don't remember seeing a piece of cloth covering that entire curved section behind both seats, until now. I haven't driven it but a couple of times, but somehow it just looks different. Could someone with a convertible look at theirs while the top is up, and let me know if this cloth covering the curved areas behind the seats is normal. I think the waterfall and the curves behind the seats is the best part of the interior.
When I pushed that button it made a grinding noise and I knew immediately that I should have waited until I had lifted the top first.
Old Apr 18, 2011 | 02:30 AM
Razzputon's Avatar
Razzputon
well I havent ever tried to open it with the top up but I can tell you that there is a piece of cloth that covers the back area when the top is up.
Have you put the top down since you heard the grinding noise?
Can you elaborate on the grinding noise? how long did it last?
Old Apr 18, 2011 | 10:34 AM
Donnasophia
Thanks, at least I know I didn't break something. Yes, I've put the top down since I hit that button that caused the noise. It is some kind of motor running for several seconds (I don't have a power top)
Old Apr 18, 2011 | 10:45 AM
DangerBrian's Avatar
DangerBrian
I have recetly bought a 2001 convertible and I can tell you what is "normal" for mine. I obviously unlatch the top from the windshield pillar then pull it back which in turn releases tension on the back part of the top which the pulls upward allowing access to the waterfall cover. I reach in a hit the button which "pops" the cover open allowing for the top the then be folded back and stored under cover as you already know. I also have noticed though that if my windows are up, when I pop the waterfall cover it automatically lowers both windows. The car obviously assumes you are going somewhere with the top down and wants you to enjoy the ride So what you may be hearing is the window motor??? Just my 2 cents....
Old Apr 18, 2011 | 10:55 AM
buckg2's Avatar
buckg2
Did your knee maybe hit the power seat button at the same time?
Old Apr 18, 2011 | 11:32 AM
Donnasophia
Thanks, It must be the power window motor. I have been putting the top down (in the garage, without driving it) to wax the waterfall and shine the dash etc.
Old Apr 18, 2011 | 11:33 AM
Donnasophia
No, didn't do that.
Old Apr 18, 2011 | 02:12 PM
65GGvert's Avatar
65GGvert
The cloth is always there with the top up, you probably just didn't notice. The only motor running when you push the button should be both power windows going down. Unless the cover unlock button was "cycling" because the cover wasn't able to pop up and that's what you heard.
Old Apr 18, 2011 | 04:58 PM
Donnasophia
I usually notice details, guess I was just too busy admiring the look of my new car. Not too crazy about that cloth covering up something that looks so great. Gonna keep it anyway.
Old Apr 18, 2011 | 05:01 PM
Razzputon's Avatar
Razzputon
Ya know I was thinking the same thing. I wouldnt mind knowing the logic behind that piece of cloth. Not only would it look better on my car but when I have the windows down and the top up it flaps in the wind.
Old Apr 18, 2011 | 05:03 PM
65GGvert's Avatar
65GGvert
On a side note, that cloth also helps protect the rear glass when the top is down.
Old Apr 18, 2011 | 05:50 PM
Donnasophia
....and I was thinking, what the heck did I do to cause this flappage.
Old Apr 18, 2011 | 05:53 PM
Donnasophia
I'm sure it does. I don't think my T-Bird has ever had any flapping and the soft top also has a rear glass window. However, it is more difficult to take the hard top off.
Old May 18, 2012 | 08:03 AM
trbomike's Avatar
trbomike
hate resurrection old posts, but i just bought a 00 vert and the cloth flapping in the wind is driving me nuts.. whats the solution?
Old May 18, 2012 | 08:59 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Start a new thread asking for advice on your own question.
Old May 19, 2012 | 01:23 PM
99 vett babycar's Avatar
99 vett babycar
That's its primary purpose.
When you press "the button" you are not actuating any sort of motor - its a lock release just like when you press "the button" to release the trunk. If you hear a motor running it has nothing to do with the hatch relase.
Old May 19, 2012 | 07:49 PM
65GGvert's Avatar
65GGvert
See what happens when you revive a year old thread that has long since been answered.
Old May 20, 2012 | 03:06 PM
tiojames's Avatar
tiojames
The noise you hear is the sound of the windows going down. Pushing the button under the waterfall activates the window down motors.
To C5 Convertible Top
