Trickle chargers
Old Apr 20, 2011 | 01:34 PM
Z28ImpalaSS's Avatar
Z28ImpalaSS
I've been using the Deltran Battery Tender Plus for about 9 years with no problems.
Old Apr 20, 2011 | 06:48 PM
ALLEGRO's Avatar
ALLEGRO
Originally Posted by corvettebob1
Hey that looks exactly like my Schumacher I've had for 15 years and it still works great. (used it on my C4 first)
When I lived in Michigan I'd hook it up when the first snow and toss on the car cover and leave it till we had a good rain in the spring to clear the salt off the roads.
I still use in here in Fl. when the car doesn't get started for 4-5 days.
I too have a Schumacher I installed on my boat back in 1997, still works, still does its job. Plugged in ALL THE TIME.
Old Apr 21, 2011 | 08:51 AM
jedblanks's Avatar
jedblanks
Originally Posted by DaBoz
I got this from Sear's... plugs into the cig lighter which for me is very easy. Cost around $24.00
I have two of these and they look the same on the outside but work completely differently. One of them will cycle between charging and charged (amber to green) when fully topped off. The other one will just stay green (and never charge again afaik). I even returned it to swap it out because I thought it was broken. I also have a schumacker (sp) from wal-mart that I think has the same guts inside. I works the same as the die hard.
Old Apr 21, 2011 | 09:07 AM
oldgoat99's Avatar
oldgoat99
Both mine cycle...
Old Apr 21, 2011 | 10:58 AM
87bob's Avatar
87bob
Veteran: Coast Guard
I use the Battery Butler 17.00 from Lectric Limited they work great. I have them on my:
99 Vette
Lawn tractor
seldom used 85 pickup truck
2007 Avalanche
They work great! Only problem I have had is we took a lightening strike which blew out a couple. But hey at 17.00 no big woop.
Old Apr 21, 2011 | 12:16 PM
rboineau's Avatar
rboineau
Whatever you buy, be sure you test/monitor its performance at first. They can be defective and overcharge your battery.
Old Apr 21, 2011 | 11:33 PM
76 VETTE's Avatar
76 VETTE
Old Apr 22, 2011 | 07:23 AM
rws.1's Avatar
rws.1
www.harborfreight.com
Automatic Battery Float Charger
Item #42292 List $12.99 often on sale.... holiday specials like Easter, Memorial Day. Labor Day etc it is usually $4.99
Talk about NO Corvette tax.
[IMG][/IMG]
I have one on each of my Corvettes. My brother uses 2 for his boat batteries, my other brother has 2 for his quads, my nephew has one on his Vette . All are over 4 years old. 1 is 7 years old.... no issues... no failed batteries.
Old Apr 22, 2011 | 10:45 AM
mophead's Avatar
mophead
So you plug your charger into the cig lighter to charge the battery? Wow, perpetual electricity!
Old Apr 22, 2011 | 12:15 PM
trussme's Avatar
trussme
Default Available from ZIP Products (Forum Vendor)
12 Volt Battery Butler $17
[/SIZE]
Zip: Corvettes Are All We Do!
http://corvette-parts.zip-corvette.com/search?w=battery%20butler&year=
Battery storage float charger is designed for the maintenance of 12-volt wet or gel cell batteries that are stored or only used periodically.
Features include:
Keeps battery fully charged without over charging. The on-board microprocessor regulates the output voltage of the charger based on your battery's demands.
Designed for long term vehicle storage. Hook up to your battery, plug it into any wall outlet, and forget it (days, weeks, months even years).
Provides a safe, regulated minimum current charge (1/2 amp) to your battery to maintain its peak capacity. Once your battery has fully charged, the charger's output current to your battery will stop - then resume as soon as battery level drops.
Short-Circuit Protected. If, for a brief moment, you accidentally touch the 2 leads of this charger together, it will not damage the charger's internal circuitry.
Includes simple to read status indicators.
Designed for use on wet-cell, gel-cell or OPTIMA batteries.
Old May 23, 2011 | 06:37 PM
VetteNY's Avatar
VetteNY
Sounds like you and me both. I bought a case of 4 Deltran BT's less than 3 years ago and I have loss 2 of them in the past 3 months already. I just posted earlier today a post asking for vette owners opinions moving forward. Over whelming response (via other sites also) is that the CTEC 3300 is HANDS down the best.
Old May 23, 2011 | 07:49 PM
Cybermind's Avatar
Cybermind
For all you Canadians out there, i strongly recommend the following:
http://www.canadiantire.ca/AST/brows....jsp?locale=en
I have been using mine for two years and it works amazingly well. I also have several friends who use it for their collector cars. It's actually on sale at 50% off this week!
Ps: I have checked the output over the last two years and it works as advertised.
Old May 23, 2011 | 10:06 PM
  #33
71corv's Avatar
71corv
St. Jude Donor '08
Use the Battery Butler purchased from Zip about 6 months ago. Has worked fine.
Gene
Old May 24, 2011 | 07:22 PM
  #34
03z06eb405's Avatar
03z06eb405
Schumacher
Old May 24, 2011 | 07:58 PM
  #35
tiojames's Avatar
tiojames
[IMG][/IMG]
Same one I use. Harbor Freight had a sale on them about six years ago for about $5.00. I bought three because I wasn't sure how long they would last. Have used one for six years and still have two unused ones in the garage.
Old Jun 26, 2011 | 02:34 PM
  #36
10.5Vette's Avatar
10.5Vette
Just thought I'd add my .02. After reading through this thread I bought a Deltran Battery Tender Plus. Well, after one month it is no longer working. I know these worked for a lot of people on here, but not for me. Anyway, ordered a CTEK today, probably should've just spent the money and bought one in the first place.
