Hypertech Question - Reassigning Shift Points on a 2000 A4
Old Apr 18, 2002 | 12:35 PM
72 LT-1's Avatar
72 LT-1
Default Hypertech Question - Reassigning Shift Points on a 2000 A4
Just got my Hypertech PPPIII and want to begin programming. I am going to raise the rev limiter to 6400 RPM to start with. I have stock tires and the 3.15 performance rear.
My question: Do any of you current Hypertech owners out there have any recommendations as to where I should set my 1-2 and 2-3 shift points for starters?
I read the manual and do not have the luxury of going to the track to beat on the car for 15 - 20 runs to decide which shift points are best. Due to the similarity of our vehicles, there must be someone out there (or maybe even several owners) that already have this process pretty well figured out.
I also would like some info on resetting the shift firmness. The options are 25%, 50%, 75% and 100%. How much of a difference is there between each of these settings? Has anyone installed a shift kit after making modifications to the shift firmness using the Hypertech? If so, was there a marked difference in how well the vehicle shifted before and after?
Thanks. All advice is welcome.
:flag
[Modified by 72 LT-1, 11:35 AM 4/18/2002]
Old Apr 18, 2002 | 02:18 PM
B. Stewart's Avatar
B. Stewart
Default Re: Hypertech Question - Reassigning Shift Points on a 2000 A4 (72 LT-1)
I am at work and can't remember how much I increased the shift points, but I know that I set my limiter to 6200 and increased the shift point by at least a couple of hundred rpm. I set the shift firmness to 75%...100%, I thought, was just too firm.
Old Apr 18, 2002 | 03:02 PM
Trevor D's Avatar
Trevor D
Default Re: Hypertech Question - Reassigning Shift Points on a 2000 A4 (B. Stewart)
With your mods, 6,000 RPM shift points would work well. I'd bump the limiter up to 6,300 just to have it out of your way. If you add a set of headers later on, bump your shift points up to 6,200. That's where I was shifting with stock internals since that's how far my engine carried power out before declining.
As for the shift firmness, I wouldn't go over 50% firmness. All the HPP3 is doing is raising the trans. line pressure electronically. Too much line pressure will kill a trans quickly. I'm not a fan of raising the line pressure electronically to be honest. I would personally have a TransGo shift kit installed. Be sure to NOT raise the line pressure electronically if you do have the shift kit installed. This will set the line pressure too high and kill the trans.
Old Apr 18, 2002 | 03:54 PM
72 LT-1's Avatar
72 LT-1
Default Re: Hypertech Question - Reassigning Shift Points on a 2000 A4 (Trevor D)
Thanks for the advice. I'll start with your recommendations on the shift points and work from there. It looks like a shift kit may be the next investment so I can keep the stock line pressure while enjoying the benefits of increased firmness while shifting.
Old Apr 18, 2002 | 03:59 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
The HPP3 doesn't raise the maximum line pressure. You are plenty safe using the shift firmness feature. :) Lots of us have lots of miles after having done that.
Old Apr 19, 2002 | 01:40 PM
jawski's Avatar
jawski
Default Re: Hypertech Question - Reassigning Shift Points on a 2000 A4 (ToplessTexan)
try this
Shift firmness @ 75%
1-2 shift - +2mph(snapped neck)
2-3 shift -+4mph (snapped neck)
3-4 shift no change
Old Apr 19, 2002 | 03:20 PM
Stu in CA's Avatar
Stu in CA
Default Re: Hypertech Question - Reassigning Shift Points on a 2000 A4 (jawski)
The last reply pretty much sums up the research I did a while back. Lots of disagreement re line pressure/trans life. Some said early death, some say longer life with greater firmness!?! I do know that one downside with increasing the firmness beyond 50% with my 3.42's is that the TC will activate on the 1-2 shift! :D
Old Apr 19, 2002 | 03:27 PM
72 LT-1's Avatar
72 LT-1
Thank you.
I just set it at 50% and didn't feel too much difference. I'll go to 75% and see what happens.
Old Apr 20, 2002 | 12:34 AM
C5XTASY's Avatar
C5XTASY
try this
3-4 shift no change
Last fall, when first trying out the Hypertech, I used +2 on the 1-2 and +5 on the 2-3 with 75% firmness. I left the rev limiter at the stock 6200 rpm. I banged the rev limiter on both shifts. So, I lowered firmness to 50% and the 2-3 shift to +4. No problems then. I may try 75% firmness again when the weather warms up, and set the rev limiter to 6300 rpm. Set your fan turn-ons a little lower, too.
Ed
Old Apr 20, 2002 | 06:06 PM
72 LT-1's Avatar
72 LT-1
Default Re: Hypertech Question - Reassigning Shift Points on a 2000 A4 (C5XTASY)
Right now I am at 75% firmness with +2 on the 1-2 shift and +4 on the 2-3 shift. I left the 3-4 as it was. So far no problems. I am going to try driving it a while like this and make any necessary adjustments after I get the feel of the car.
When I programmed my car, the Hypertech module indicated that the tuing was completed, however, just as it finished, the DIC on the car came up with a reading that said "Reduced Engine Power." Has anyone else noticed anything similar?
Old Apr 21, 2002 | 12:22 PM
C5XTASY's Avatar
C5XTASY
Ed
I forgot to mention that the rev limiter hits resulted from spinning the tires on the shifts, not from the actual shift point. It didn't happen every shift, but often enough that I did not want it to be a common occurance. It scared the crap out of me when it did it the first time. I thought I wiped something out. :eek: :D
Ed
Old Apr 21, 2002 | 12:28 PM
Vespa-Vette's Avatar
Vespa-Vette
The Hypertech screws with your dash read-out. The programming always seems to work, but I've had my entire dash go down (i.e. you can crank and run the car but all the gauges read "0" and there's some odd error message like "reduced engine power" on the display. You just have to hook the programmer back up & let it re-establish communications and then cancel back out of the install and the dash will come back to life.
I don't know what causes this. Maybe it's a dip or spike in voltage while you're programming.
This really freaked me out the first time it happened. The dash just needs to reset. There's a way you can reset the dash with the gauge bottons (something like hold down the reset button while pressing the fuel button 4 times) but that never seemed to help.
Old Apr 21, 2002 | 12:39 PM
ToplessTexan
Pretty typical but not unique to HPP3. The various modules are commanded to stop communicating when flashing the PCM and you end up with codes. Just clear the DTCs (the procedure is in the C5 FAQ section if you need it ;)) and you're good to go. My HPP3 did it about 1/3 of the time, I see it all the time using LS1-Edit.
Old Apr 21, 2002 | 08:35 PM
72 LT-1's Avatar
72 LT-1
Thanks. I'll give it a try during the week.
To Hypertech Question - Reassigning Shift Points on a 2000 A4
