Those w/ Iron blocks chime in
Old Apr 20, 2011 | 02:46 PM
02*C5's Avatar
02*C5
Default Those w/ Iron blocks chime in
I have a friend who is deployed at this time. He has bought a 415 iron block for his C5Z. He is looking for a 9 sec street car. So we get into a discussion about drive-ability, cooling issues, and weight.
I told him that he is adding 90lbs to the car, it is not going to handle the same, and that there might be cooling issues. The shop doing the swap told him that yes its weight added, but drive ability, handling and cooling issues are not going to be a problem.
Any info that any one can give me good or bad I can pass a long I'd appreciate it.
Old Apr 20, 2011 | 02:55 PM
tlove32's Avatar
tlove32
No different than adding a supercharger. Just have the car corner balanced and aligned and it'll be fine. As for cooling - a dewitts radiator and 160 t-stat will keep things nice and cool
Old Apr 20, 2011 | 03:33 PM
02*C5's Avatar
02*C5
Old Apr 21, 2011 | 06:58 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Here is some of my info on my old 97':
http://forums.corvetteforum.com/auto...t-install.html
An oil cooler will be key.........no worries on the 80lbs in the front.
I run a built A4, 417 stroker(6.0 truck block) bone stock F45 suspension, 3.90 gear and have 2 tranny coolers and the stock radiator w/160 t-stat.
CAI is Vararam so the radiator is unobstructed.........coolant is 180-220(running in 100 deg stop & go VA traffic or 170 mph on a road course )
I road race, drag race and drive this car on 900+ mile trips w/o issue
http://forums.corvetteforum.com/c5-t...r-install.html
Old Apr 21, 2011 | 01:14 PM
fsuforever's Avatar
fsuforever
I agree about adding a dewitts & maybe some spal fans to keep things cool,I'm running an iron 403 & my coolant temps run around mid 190s & the oil temps hover around 230,this with a novi 2k
To Those w/ Iron blocks chime in
