Need Mechanics help
Old Apr 20, 2011 | 06:04 PM
convertible lover's Avatar
convertible lover
Default Need Mechanics help
I have a 2000 vert with about 90,000 miles on it. Not sure maybe two years ago I was running thought some curves and power steering seem to quit. It felt hard to steer. I stopped and checked out everything. It all looked good, took off with no more trouble. Steered great. Then over the weekend while running though some curves on one curve only I felt the steering get hard, next curve it felt fine.
So what am I looking at? Talked to two mechanics today, got two different answers. Am I worried over nothing? Or am I looking at the pump, or rack and pinion going out. Thanks for any help or advice you can give.
Old Apr 20, 2011 | 10:40 PM
98c5lswon's Avatar
98c5lswon
Got any dtc's? Changing the power steering fluid would be a good place to start. Also were there any abnormal noises during the time when your steering was hard? Power steering pumps usually dont intermittently go bad,its more of a gradual failure. Sounds like some sort of hydraulic valve sticking, i believe those would be internal to the rack and pinion but im not sure.
Old Apr 20, 2011 | 10:45 PM
convertible lover
Heard no noise at all. Just hard steering. And it only happen twice, two years apart. Has nobody heard of anything like this before.
Old Apr 20, 2011 | 10:58 PM
Jnape's Avatar
Jnape
The Magnasteer steering assist could be getting funny.
Pull Your Codes
Old Apr 21, 2011 | 09:20 AM
NealB's Avatar
NealB
I had a similar situation but in a long busy autocross course on a really hot day with two drivers
power steering fluid got too hot and pump cavitated
replaced with Red Line fluid and no further issues
Old Apr 21, 2011 | 12:35 PM
imavettegirl's Avatar
imavettegirl
fluid is pretty old, replace it.
Old Apr 21, 2011 | 12:38 PM
1stGlance's Avatar
1stGlance
CF Senior Moments Member
Much better scenario than ball/joint socket issues or some weird binding caused by cornering force.
To Need Mechanics help
