Rear Brake problem
Old Apr 20, 2011 | 08:07 PM
Carveman's Avatar
Carveman
8th Gear
Default Rear Brake problem
I cannot get the rear brakes to bleed. The pedal goes to the floor on the fronts when open. The pedal on the rear only travel a short distance before hitting resistance and it almost sound mechanical. The fluid only dribbles out on both sides. I've changed to bleeders, as suggested by those here and tested for air leaks with a stick of incense. I changed the rotors, pads and installed SS brake line. Is it possible it may be a problem in the master cylinder. I appreciate having the forum to turn to.
Mike
