Battery tray clamp down bolt specs?
Old Apr 21, 2011 | 03:10 PM
ColeTrain'sC5's Avatar
ColeTrain'sC5
Default Battery tray clamp down bolt specs?
I need to find a replacement for the one that goes thru the black block that holds down the battery. I lost mine and i just want to go to a hardware store and get a bolt. Anybody have specs? ~Cole~
Old Apr 21, 2011 | 03:53 PM
bumble-z's Avatar
bumble-z
I believe you need an M8 X 1.25 2" long.
You would need to grind the end down to a point.
Push the bolt through the blk plastic block & put a (paper thin) push nut on the
bolt on the back side of the blk plastic block. That way it will be as the original & you won't ever loose it?
Old Apr 21, 2011 | 04:09 PM
lucky131969's Avatar
lucky131969
specifically......M8 x 1.25 x 55
Old Apr 21, 2011 | 04:11 PM
ColeTrain'sC5
Thanks much guys Appreciate it, I think the local hardware store has this style bolt already so we're good
Old Apr 21, 2011 | 05:02 PM
ColeTrain'sC5
Hat's off to you gentleman I went and got a bolt for $1 and washer for $.35 and it works perfect. It isn't a tapered end but it bolts in just fine
Old Apr 21, 2011 | 07:17 PM
Bill Dearborn's Avatar
Bill Dearborn
Next time you need something like that go to Lowes. They have a very nice assortment of automobile style fasteners. Just checked a few and they seemed to be better stocked than the local stores of the national chains which are getting pretty limited in what they offer.
Bill
To Battery tray clamp down bolt specs?
