02Z w 1 7/8 headers, do these need to be removed, or just loosened to install new clutch? If they do have to be removed, I want to have a new gasket ready to install.
when i did my clutch you have to unbolt the headers, but can leave them hanging in the engine bay.... i have reused the stock gm gaskets with no problems
Thanks, I was just researching and it seems that is the way to go, but are the one's made by other co.'s just as good as the GM? No problems using w 1 7/8 headers?
I found these:
SCE Pro Copper Exhaust Gaskets Chevy LS1 LS7 Lg round port 1.75
i reused stock gaskets twice and no problems. After 2 heat cycles i just retighten the bolts and never had a leak. They will probably have to be unbolted from the heads and then tipped down.
