Fault code repair suggestions
Old Apr 23, 2011 | 03:58 PM
cruisemon's Avatar
cruisemon
Default Fault code repair suggestions
I didn't drive my '98 6-speed for a couple of weeks. When I started it this morning, it lit up with no problems. After had driven maybe a mile I pushed in the clutch and the engine rpm dropped, and then the engine shut off. It does this any time I push in the clutch while I am moving. If I am sitting still the engine will eventually idle but hunts between maybe 500 and 1000 rpm, and runs a little rough. When I first start off, there is a minor hesitation but once the engine speed is above about 1000 rpm or so it cleans up and runs smoothly. After several starts I go a CEL
Faults codes are
PCM P0101 - MAF system performance, history
IPC U1160H, Lost communications, history
AOLDMC B2252, history
I'll start shooting trouble on it tomorrow. About six months to a year ago I removed and cleaned each of the grounds (at least I think I did)
Any chance anyone recognizes the symptoms and codes and can share how they fixed it? Any thoughts on the most likely culprit, what to check and how to check it, and how to fix it would be greatly appreciated.
Charlie
Ch
Old Apr 24, 2011 | 10:51 PM
cruisemon's Avatar
cruisemon
Found it!
The boot between the MAF and the filter was loose. That's because I lost an argument with a curb a month ago that whacked the skid plate, a horn, the steering position sensor, the front bumper unit, one fog light and both Z06 grills. It also broke the upper radiator support that lets the MAF flop around and come loose.
Back to the body shop.
Charlie
Old Apr 25, 2011 | 08:25 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I just saw your post and was going to suggest looking at the air-bridge but you found the cause already. Cool. Sorry about the problems.
To Fault code repair suggestions
