Buying New Clutch
Old Apr 24, 2011 | 10:38 AM
dustysZ's Avatar
dustysZ
Default Buying New Clutch
Am in the market for a new clutch. Looking for some suggestions. I have a 02 ZO6 doing about 450 at the rear wheels. Might add up to another 100 hp sometime in the future. This is pretty much a daily driver as long as the weather is good up here the the Chicago area. Do not track the car. Just like to have fun with it you know kill a few mustangs and hemi cars.
Old Apr 24, 2011 | 11:01 AM
Last C5's Avatar
Last C5
I have an 01 Z with 450 RWHP that I do track. I used the 7.6 dual disc Fidanza and an aluminum flywheel. Great clutch. Even with the aluminum flywheel it's very streetable, but you might want to go with steel or billet flywheel to maintain a totally stock feel.
Old Apr 24, 2011 | 11:15 AM
81c3's Avatar
81c3
Im running a Monster Level 2 Its very street friendly. I believe its rated at 525hp I had a Level 3 puck type and its a bit much for the street imho.
Old Apr 24, 2011 | 11:51 AM
kp1's Avatar
kp1
In your case I think I'd just stick with the LS6 clitch kit or maybe step up to the LS7 clutch kit. Some of th aftermarket stuff requires substantially more pedal effort and that could be a PITA for a daily driver.
I've had good results with the ACT street kit - rated to 750 lb ft of torque and so long as you get a flywheel that's properly surfaced it has clutch engagement as slick as the oem units.
Old Apr 24, 2011 | 03:14 PM
Choose1's Avatar
Choose1
I ran the Centerforce Dual Friction (rated at 550hp) for 6 months at 420rwhp then installed my STS kit and ran it for another 6 months at 520rwhp. No problems at all, feel like stock and grabs well.
I may be getting rid of mine to step up to a twin disk (McCleod or RSP?) as I hunt down 750rwhp........
Old Apr 24, 2011 | 04:04 PM
LoneStarFRC's Avatar
LoneStarFRC
McLeod RST dual-disk and your surfaced flywheel. Smooth, streetable, affordable and near-stock pedal feel.
Old Apr 24, 2011 | 09:59 PM
Ed@TheVetteDoctors's Avatar
Ed@TheVetteDoctors
Supporting Vendor
Pedal is like stock...no more work outs good to 800 hp, RXT if you need more
__________________
Vette Doctors Performance aka The Vette Doctors
52 Elm Place, Amityville, NY 11701 info@thevettedoctors.com or http://www.thevettedoctors.com/
(631) 841-0779
Featuring EFI Live/HP Tuners Performance Tuning in-house or remotely and HP Tuner/EFI Live training by ERM Performance Tuning
www.ermperformancetuning.com
Old Apr 26, 2011 | 07:21 AM
dustysZ's Avatar
dustysZ
Thanks for the input the guy who tuned my car also says the Mcleod. Guess with all this expert advice I now know what to do.
Old Apr 26, 2011 | 08:41 AM
chevy406's Avatar
chevy406
I ran a Textralia z-grip (puck style) for 1½ years in my daily driver. It works great at the drag strip with sticky tires, but had too much chatter for my likes on the street. I swapped it for an LS7 clutch, which works great (as expected) for daily driving but it doesn't hold my 470whp very well at the drag strip.
So you have two variables to consider:
1) Duty: if primary use is daily driver and only want to test at the track every now and then you can get by with an LS7 or other single disk aftermarket clutch (stay away from the puck style). If you want daily driver and good performance at the drag strip, then step up to the twin disk clutches.
2. Budget: Low budget single disk. Baller, tax-refund kind of guy jump on a twin disk and have the best of both street and track manners.
Old Apr 26, 2011 | 10:48 AM
Chicago1's Avatar
Chicago1
I did a review of the Mcleod rst I just installed. I was coming from a Spec 3 with f1 racing 16lbs flywheel. I hated that clutch it was chattery and My left leg got a work out. It was good the first few months but just seemed not to perform for me after that. I switched to the RST/Steel flywheel combo and the differnece is night and day. No more leg workouts I actually think it's lighter then the stocker. Very little chatter, your grandma with a broken hip could engage this thing with no issues. Holds 850 torque. I love it and wished I would of done it the first time. You won't see many negative if any actually of the R series clutches from Mcleod. The others above I here both positive and negative. I got mine from HinsonSupercars
Old Apr 26, 2011 | 01:32 PM
scott1974's Avatar
scott1974
I had the Monster Level 2 and loved it. Stock feel with a ton of grip.
Old Apr 26, 2011 | 02:09 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
To Buying New Clutch
