Help - Driveshaft Removal Tool
Old Apr 24, 2011 | 05:18 PM
Yellow Z's Avatar
Yellow Z
Default Help - Driveshaft Removal Tool
Looking for advice. I am replacing my clutch and decided to swap the factory driveshaft for a new carbon fiber driveshaft. Shop manual calls for tool J 24420-C with a hammer puller J 2619-01. Cannot find J 2619-01 on the web. J 24420-C is on the web and referred to as a universal puller/harmonic balancer puller. I rented an axle puller tool from the local parts store but the bolt patter on tool is not correct. I see a lot of harmonic balancer puller sets on the web. Has anyone done this before and do they have any suggestions as to tools that I can use? Are the bolt patterns for all harmonic balancer tools the same? By bolt pattern, I am refering the location of the bolt slots.
Old Apr 24, 2011 | 08:39 PM
RobertEarl's Avatar
RobertEarl
Large snap-ring pliers and tap the rear with a rubber hammer. Not sure why you need those tools.
Reb
