Wire Insulation Degradation
Old Apr 25, 2011 | 04:47 PM
Atok's Avatar
Atok
Default Wire Insulation Degradation
While changing my battery today look what I found. It's a ground wire coming from a wiring harness. The insulation is missing and very brittle. I believe heat from the heater hoses may have contributed to this but I'm not sure. The farther away from the heater hose the better the insulation. I replaced the wire but I wonder if there are other more critical wires in hot spots with the same issue.
Anyone else see this on this wire?
Old Apr 25, 2011 | 04:53 PM
lucky131969's Avatar
lucky131969
Looks more like rodent damage to me. Radiation from a heater hose, will not cause that problem.
Old Apr 25, 2011 | 05:32 PM
Atok's Avatar
Atok
Not likely. The insulation just crumbles in my fingers. Definitely some sort of degradation of the plastic.
Old Apr 25, 2011 | 06:21 PM
lucky131969
Yes, precipitated by corrosion. Once the wire is exposed, it corrodes...expands, etc.
Old Apr 25, 2011 | 06:27 PM
lvictores's Avatar
lvictores
I agree that it looks like the critters got a hold of it as that's how my wires looked right under the battery. Look for nests of leaves under the battery or inside the front fender. They apparently like to set up home there.
Old Apr 25, 2011 | 06:36 PM
Atok's Avatar
Atok
I stand corrected, it is rodent damage! I looked closer at other wiring in the same area and there are signs of nibbles but nothing as bad as this wire.
No sign of a nest under the battery. Nothing visible from the top. Going to pop the inner fender cover off and take a peek inside.
Man am I ever annoyed now!
To Wire Insulation Degradation
