Oil Sensor Access
Old Apr 26, 2011 | 09:25 AM
KCUHC's Avatar
KCUHC
Cruising
Default Oil Sensor Access
After all the discussion on how to replace the oil pressure sensor on my C5, I’m still not sure which way to go. There was mention of cutting a hole in the cowl to reach the sensor and apply the proper torque. Is that hole cut in the plenum in the engine compartment above the sensor location? If so, this sounds like a way to go for me. Could anyone be more specific on this method of access to the sensor?
Any input or advice is appreciated.
Sarasota Chuck
Old Apr 26, 2011 | 09:50 AM
chevy406's Avatar
chevy406
I don't know why so many people resist pulling the intake manifold. You can have the intake off in 20 minutes or less - at least after you've pulled one a time or 12...
With that being said, I've cut the cowl on 2 cars in order to replace the oil sending unit, but that was before I realized how easy it is to pull the intake. Access from the top starts with pulling the windshield wipers, remove the cowl cover under the wipers, then locate the point directly above the oil sending unit and cut out an access hole big enough to fit your socket wrench into & part of your hand. Do not over tighten the sending unit.
Here is where I cut my cowl 4 years ago. The replacement sensor is still working over 100k miles later...
Old Apr 26, 2011 | 10:20 AM
lucky131969's Avatar
lucky131969
Sarasota Chuck
It is not mentioned in the posted "procedures" (although, brought up by 8VETTE7), be aware of the wiring. The 5 volt reference wires are right in that area. All you have to do is nick the wiring, and the car will barely run......if start at all. Good luck.
Old Apr 26, 2011 | 10:29 AM
mchicia1's Avatar
mchicia1
Just pull the manifold, it is not hard. Do you really want to be cutting into your car?
Old Apr 26, 2011 | 12:29 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
All you will ever need to know, about replacing or relocating an oil pressure sensor, can be found in the link below.
http://forums.corvetteforum.com/c5-t...-relocate.html
Old Apr 26, 2011 | 12:59 PM
lucky131969
....except for the pitfalls:
http://forums.corvetteforum.com/c5-t...-terrible.html
Old Apr 26, 2011 | 01:06 PM
Vettmann17's Avatar
Vettmann17
Before cutting the hole in the cowl, take something like an old license plate or similar and slide it between the cowl and the wiring/tubing that is under the cowl to protect them from being nicked by the blade.
Old Apr 26, 2011 | 01:58 PM
BigGun's Avatar
BigGun
Must be an echo in here.
Old Apr 26, 2011 | 02:06 PM
Florida99's Avatar
Florida99
Old Apr 26, 2011 | 02:15 PM
Vettmann17's Avatar
Vettmann17
Your right. I skimmed through the posts and didn't see it's already been said. Thats what I get for not paying attention! Good advice none the less.
Old Apr 26, 2011 | 07:01 PM
Quicksilver Vert 01
Originally Posted by lucky131969
Good info Mike!
I'm sure that you already know my feelings about cutting a hole blindly to replace an oil pressure sensor.
Old Feb 24, 2013 | 09:16 PM
nuts105's Avatar
nuts105
Default just a hole
Could the proponents of the hole cutting theory please tell me how they manage to pull off the electric connector through that hole?
I had to enlarge the hole, and even so it was an act of acrobatics to get a screwdriver and pliers in there to get that damn connector off, with the vacuum hose leaving no space to grab it properly. Or is that just another difference of my 98's routing? Oh did I mention I removed the wiper motor assembly to even have a chance of cutting a big enough hole (with a dremel)? The one thing that didn't matter at all was the concern about cutting some wires. No wires leaning against the firewall in my car. Also I have no qualms cutting a hole into some plastic you don't see, and yes it isn't hard to seal it back up.
Old Feb 24, 2013 | 09:44 PM
dmarkshark's Avatar
dmarkshark
How about a straightened out coat hanger with a hook on the end to pull up on?
To Oil Sensor Access
