Braking shimmy
Old Apr 18, 2002 | 11:49 PM
Black01Coupe's Avatar
Black01Coupe
Default Braking shimmy
My vettes got about 17500 miles on it. Today I noticed when coming to a stop at lights the front end has a shimmy to it. I can also feel it through thee steering wheel when starting off slowly from the light. Would this be warped rotors? If so would it be warranteed?
Old Apr 19, 2002 | 12:13 AM
Trevor D's Avatar
Trevor D
Default Re: Braking shimmy (Black01Coupe)
Yep, your rotors are warped, and it should easily be covered under warranty. I know plenty of f-bodies that had them replaced under warranty w/ no problems.
Old Apr 19, 2002 | 12:19 PM
rocketrider2's Avatar
rocketrider2
Default Re: Braking shimmy (Trevor D)
Actually rotors, clutch , etc are not covered under the warranty. The dealer may do itas goodwill, but those parts arenot covered by the mfg warranty.
Old Apr 19, 2002 | 12:24 PM
borba's Avatar
borba
Default Re: Braking shimmy (rocketrider2)
If you feel it through your steering wheel at higher speeds and you are not pressing your brakes check the balancing of the front wheels. :seeya
Old Apr 19, 2002 | 12:34 PM
2KVetteMan's Avatar
2KVetteMan
Default Re: Braking shimmy (borba)
I just took my Vette in because my brakes were pulsating. The rotors were bad. $155.00 to repair them or resurface them. Not covered under warranty. Although I do have 36,000 miles compared to yours, you might get away from paying for it, just be a little hard, your rotors should not be going out at 17000 miles period.
Good luck!!!
Old Apr 19, 2002 | 06:17 PM
LowFlight's Avatar
LowFlight
St. Jude Donor '03, '17
Senior Member
Cruise-In V Veteran
Make sure that when you replace or turn the rotors that you use the exact tourque for the lug nuts...this helps alot :D
Old Apr 19, 2002 | 06:45 PM
Black01Coupe
Default Re: Braking shimmy (2KVetteMan)
I guess I'll see what the dealer can do on tuesday. If they won't warranty it I guess my next order of business should be saving for eradispeeds.
To Braking shimmy
