Knocking Noise
Old Apr 30, 2011 | 07:43 AM
TomsZ06's Avatar
TomsZ06
Default Knocking Noise
Sometimes when I am slowly turning right into a parking spot I hear this loud knocking noise coming from my front suspension. It only happens once as if something is binding and suddenly releases causing the knocking sound. This only happens in this type of condition, no other time.
Old Apr 30, 2011 | 10:27 AM
Jewjenk's Avatar
Jewjenk
Sounds like one of your CV joints is gone..................
Put on lift and inspect front suspension. Or take to a repair shop that knows front ends and let them inspect it.
Old Apr 30, 2011 | 02:49 PM
RTE61's Avatar
RTE61
I had the brake line pop out of the clip holding it in. although it only changed positions slightly it was enough to catch the tire nubbs on a sharp slow turn to pull line and release for a noticeable knock sound.
Old Apr 30, 2011 | 04:36 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
There are no CV joints in the front.
Old Apr 30, 2011 | 04:56 PM
Jewjenk's Avatar
Jewjenk
At work, thinking too quick............You're right.........
Old May 1, 2011 | 08:16 AM
CHJ In Virginia's Avatar
CHJ In Virginia
On my 2001 coupe, I had a similar noise problem when turning at slow speed. Although it sounded like the noise was coming from the front, it was from the rear axle splines. The splines get dry and cause clicking on turns. Get car up on jackstands, remove rear wheels, remove large 33MM nut on halfshaft and liberally soak the splines in lubricant. Reinstall and torque nut and wheels. You should be good to go and quiet.
Old May 1, 2011 | 09:01 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I had a noise like that on my '99 when pulling into a driveway where I worked...at a specific angle. I got under the car and put a wrench on every nut and bolt I could find till I came across the right tie-rod end nut was just a hair loose. Problem solved.
Old May 1, 2011 | 10:54 AM
81c3's Avatar
81c3
Assuming by your username you have a Z. I have read that on the FRC the body panel behind the seat has some level of flex. When turning it sounds like someone pounds the side of the rear body panel with a fist. There is a fix, but I cant remember what or where it is....
Old May 1, 2011 | 03:05 PM
flynhi's Avatar
flynhi
I have been told by a local Vette mech that the noise could be from sway bar end links being overtighened (over 53 ft lb torque) or interference between the spring end and A arm on lowered cars.
Any opinions on this?
Old May 2, 2011 | 07:56 AM
TomsZ06's Avatar
TomsZ06
Thanks for all your replies. Does anyone have a suggestion where I could go in the Tampa Bay area to have this looked at? I am leery about just taking it to one of the local national chain shops?
Old May 2, 2011 | 10:18 PM
flynhi's Avatar
flynhi
My noises have worsened. By disconnecting one end of the sway bar, I can determine if the noise is from the end links or not.
Any danger in doing this so long as I don't drive too aggeressively?
Old May 3, 2011 | 04:03 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
I had a clicking noise when turing the wheel and it was the front bearing hub bolts were loose. Tighten them and noise went away.
To Knocking Noise
