c5 front spring, shipped bad part?
That thick rubber side of the mounting pads goes to the bottom & the thinner part is on top. Looks as though (on mine) that they are (black)glued/caulked in place.
You can see the black sealant to the outside of the rubber mount pads & to the spring.
Did you buy that spring from GM?
On the driver's side bottom of the spring there is a circle with the numbers 22171750 stamped into the spring.
Who ever manufactured the spring, put the rubber mount pads to the wrong sides.
Good luck.
My spring rubber pad is smashed bad and the adjustment bolt won't budge, rust and just locked up! Thinking of replacing the whole spring. My car has 98K on it so suspension is getting a face lift.
Thanks,
Pinto
Thanks,
Pinto
I would pull the spring out.
Then apply plenty of PB Blaster to both sides of the spring, where the adjusters come through the spring.
I'd do this several times a day for several days.
Set the spring in a vise, add a small amount of heat
(to the threaded end of the adjuster) & apply a pipe wrench or very large channel locks...to the rubber end of the adjuster.
If it moves a bit & then stops, repeat the process again.
Hopefully this procedure will get the old adjusters out.
Make sure to have two replacement adjusters on hand, to re install.
Good luck.
Good luck.
S
