LS6 intake is on - learned a few things
Old May 3, 2011 | 01:47 PM
10.5Vette's Avatar
10.5Vette
Originally Posted by CD
Sure hope you did the remote OPS relocation while you had the manifold off.
New to C5's what is the OPS relocation?
Old May 3, 2011 | 02:04 PM
mcm95403's Avatar
mcm95403
Oil Pressure Sender
It's buried behind the intake and they are known to have issues. Mine looked mint so I followed the old "if it ain't broke don't fix it" mindset.
Old May 3, 2011 | 02:06 PM
mcm95403's Avatar
mcm95403
Originally Posted by 83Camaro
For someone who has a 99 also with a stock motor with blackwing, is ls6 intake worth it would i even notice a difference?
My engine is all stock internals, only the mods listed in my sig. I'm sure you'd notice the improvement.
Old May 3, 2011 | 02:45 PM
robert123's Avatar
robert123
Were you able to reuse your old fuel rail covers? I am installing a LS6 intake as well and someone told me my 98 will need newer fuel rails.
Old May 3, 2011 | 03:22 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
Well, at least you're familiar with removing the intake now.
Old May 3, 2011 | 05:44 PM
lucky131969's Avatar
lucky131969
You don't need new fuel rails, you just can use the red coil covers.
Old May 3, 2011 | 06:02 PM
JaxC5's Avatar
JaxC5
That vacuum line in the back is a PITA.....I went ahead and removed the coolant lines and bought the plugs for the rear, wish I would have saw the post prior to doing the swap.
Old May 3, 2011 | 06:44 PM
mcm95403's Avatar
mcm95403
Yes, the intake was the ONLY part I changed. Stock 99 fuel rail covers fit without issue.
Old May 3, 2011 | 06:48 PM
lucky131969
He has a 98, which means there are two lines to the fuel rail....one feed, one return. 97-98 fuel rail covers are unique, in that they have two slots for the lines.
Old May 3, 2011 | 07:21 PM
zeevette's Avatar
zeevette
I think it's a great idea to retain the crossover coolant tubes. The factory says you don't need them, but anything that helps equalize coolant temps is a good thing. I don't know if it really does this, but it's sure cheap and easy, and won't cause any harm.
Old May 4, 2011 | 09:44 AM
mcm95403's Avatar
mcm95403
Ah, I didn't know that.
Old May 5, 2011 | 01:49 PM
mcm95403's Avatar
mcm95403
An added plus - my mileage went up too
http://forums.corvetteforum.com/c5-g...r-mileage.html
Old May 5, 2011 | 07:00 PM
  #33
Lifted07Sierra's Avatar
Lifted07Sierra
From start to finish how much did all the parts cost
Old May 5, 2011 | 07:12 PM
  #34
mcm95403's Avatar
mcm95403
DUDE, don't make me add it up!
I did get a GOOD deal on the intake - $225 shipped.
Old May 6, 2011 | 12:40 AM
  #35
soggysailor's Avatar
soggysailor
I think the HARD part is finding a decent price on a LS6 intake!
Old May 6, 2011 | 06:57 AM
  #36
baxsom's Avatar
baxsom
agreed, average cost used is 3-4 hundred. it took me about a month for someone to be willing to let one go for 325.
Old May 6, 2011 | 09:14 AM
  #37
mcm95403's Avatar
mcm95403
I used http://www.searchtempest.com/ to search Craigslist for the whole country and found it in Alabama.
To LS6 intake is on - learned a few things
Old May 6, 2011 | 01:14 PM
  #38
MrGary2011's Avatar
MrGary2011
You should of swapped out the valley pan for a LS6 one and gotten rid of the PVC hose fiasco! Down the line your hoses will deteriate, something to consider and a much improved cleanup of the engine bay, with that I would also recomend a oil catch can since you like to hit the gas peddle, this will eliminate a bunch of gunky oil going back into you nice LS6 intake!
Old May 6, 2011 | 01:19 PM
  #39
MrGary2011's Avatar
MrGary2011
As far as the fuel rails are concerned on the 98 you will need to remove the fuel rails on the LS1 intake and mount them on the LS6! They are a perfect fit (get some new O rings)! Anyone need the LS1 intake or LS6 fuel rail?
Old May 6, 2011 | 08:02 PM
  #40
LoneStarFRC's Avatar
LoneStarFRC
Post #26
