Powerloader HP & Torque Gains...
Old Apr 19, 2002 | 01:15 PM
YLWFVR75's Avatar
YLWFVR75
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
Default Powerloader HP & Torque Gains...
Anyone have any valid info regarding your gains made from the Powerloader alone......
thanks
Old Apr 19, 2002 | 06:06 PM
golfman's Avatar
golfman
St. Jude Donor '05
Default Re: Powerloader HP & Torque Gains... (y2k02c5)
Dont really now I haven't dynoed yet but there is a huge SOTP feeling. Best mod for the money. None better
Old Apr 19, 2002 | 06:44 PM
imxz28's Avatar
imxz28
Default Re: Powerloader HP & Torque Gains... (golfman)
What year model do you have ??
Old Apr 20, 2002 | 12:21 AM
C5XTASY's Avatar
C5XTASY
thanks
The fact that the Powerloader is WAY more popular with the A4 bunch probably says the bulk of the performance difference is in shifting charactertistics of the automatic and not horsepower and torque gains. The M6 guys don't seem to have seen much difference. Do a forum search and I think you'll see what I mean...:yesnod:
Ed
Old Apr 20, 2002 | 07:36 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
It was originally advertised at 10-12 hp, realistically I would say half, but the torque management for the A4 is one bad mother!
Old Apr 20, 2002 | 07:56 PM
Vespa-Vette's Avatar
Vespa-Vette
Default Re: Powerloader HP & Torque Gains... (wallstAL)
Loaded the TTS Powerloader on my 2000 A4 w.315 axle this morning. I LIKE the shift and transmission response.
I was disapointed on the dyno.
Stock 2000 (K&N airfilter & '02 LS6 filter cover)
Today after Powerloader install: HP= 294.8 Torque=302.1 (both SAE corrected)
These were numbers I'd expect to see prior to the computer tunning. Thus, I don't think that you really pick up any HP with the powerloader. But those of us with A4 trannies will appreciate the change in transmission response. I also had a Hypertech III but the Powerloader is a much better transmission manager. No real HP gains with either one.
Old Apr 21, 2002 | 01:26 AM
2001 Red Coupe Bandit's Avatar
Default Re: Powerloader HP & Torque Gains... (Vespa-Vette)
Good seeing you at the dyno today. Don't be too dissapointed. Those are just numbers. Heck, you already won 1st place in your class at Big Bend, be happy for that!
Talk to you later
The Bandit......................
[Modified by 2001 Red Coupe Bandit, 11:28 PM 4/20/2002]
Old Apr 21, 2002 | 02:13 PM
Vespa-Vette
Default Re: Powerloader HP & Torque Gains... (2001 Red Coupe Bandit)
Bandit,
I was looking at my dyno printouts (3 pulls) and noticed that my max hp was acheived between 3,800 & 4,800 RPMs. After about 4800-5000 RPMs the hp droped off by about 10 hp and holds steady out to about 6,200RPMs. I didn't dyno before the powerloader so I don't know what stock looks like. Max torque hits and immediately starts falling off at about 5,200 to 5,300 RPMs with a very steep decline. Do you have a similar pattern on your reports?
Also, my air/fuel ratio always starts out at 13 until I hit 5,100 RPMS and then it falls to 12. Does your's do the same? Is this also a function of the Powerloader?
Old Apr 21, 2002 | 05:32 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Loaded the TTS Powerloader on my 2000 A4 w.315 axle this morning. I LIKE the shift and transmission response.I was disapointed on the dyno.Stock 2000 (K&N airfilter & '02 LS6 filter cover)Today after Powerloader install: HP= 294.8 Torque=302.1 (both SAE corrected)These were numbers I'd expect to see prior to the computer tunning. Thus, I don't think that you really pick up any HP with the powerloader. But those of us with A4 trannies will appreciate the change in transmission response. I also had a Hypertech III but the Powerloader is a much better transmission manager. No real HP gains with either one.
First you need a good air intake like the Vortex, with PL I dynoed at 307 hp. My max hp came from 5300 to 6100 rpms (stock cam), read your graph again!
Old Apr 21, 2002 | 06:20 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
I loaded at the track....did pre and post runs....I gained 2/10ths, same nite, same track, pre and post runs made within minutes of each other :cheers:
Old Apr 23, 2002 | 10:11 PM
golfman's Avatar
golfman
St. Jude Donor '05
Default Re: Powerloader HP & Torque Gains... (imxz28)
I have a 2002 C5 coupe
To Powerloader HP & Torque Gains...
