Weird
Old May 2, 2011 | 08:47 AM
didntdoit11's Avatar
didntdoit11
St. Jude Donor '12
Default Weird
Deleted the the air pump. And welded the manifolds where the pump went to. Took off rear o2s and no codes
Hmmmmm weird
Old May 2, 2011 | 11:12 AM
The Wrench's Avatar
The Wrench
Ha; just wait awhile. Often you have to drive it on the highway at a steady speed for quite awhile before the codes will set.
I noticed some of the guys have posted about installing a little "anti-plug-fouler" spacer under the rear sensors to disrupt the flow to the sensor and stop the codes from setting. That's so weird in itself it just might work - I love that shade-tree ingenuity stuff.
DG
