A/C Air Flow Keeps Moving
Old May 3, 2011 | 06:25 PM
leemelone's Avatar
leemelone
Default A/C Air Flow Keeps Moving
I have a 98 C5 w/88,000 miles. When I turn on the AC, the air blows out of the defroster vent initially but keeps changing vents. It will then blow out of the upper and lower vents briefly and then back to defrost over and over. It doesn't matter what the settings are. I tried disconnecting the battery to reset the actuator with no luck. I'm unable to check the codes. Is this a vacuum problem? An actuator problem? The control unit?
Old May 3, 2011 | 10:01 PM
dmarkshark's Avatar
dmarkshark
What type of unit do you have , automatic dual zone or manual?
Old May 3, 2011 | 10:09 PM
leemelone's Avatar
leemelone
It's the automatic dual zone.
Old May 3, 2011 | 10:49 PM
dmarkshark's Avatar
dmarkshark
I know someone on here can give you a lot better directions then myself. But, this sounds like a vacuum issue. There is a line that comes from the back of the engine, travels down through the area under the battery, and I believe to an air canister, and into the passenger foot area. You should probably check that line first by going under the dash on the passenger side. Remove the lower panel, and you will see an electronic selonoid with all of the vacuum lines, check the single line to the selonoid first. I really don't want to give you bad advice so I hope someone else will step in to give your better directions. That will at least get you looking in the general area.
Old May 4, 2011 | 01:22 AM
Old Horsepower's Avatar
Old Horsepower
Do you have it set on AUTO? When I use that it really has a mind of its own. Fan speed changes, vents change, compressor turns on and off.
Old May 4, 2011 | 07:16 PM
leemelone's Avatar
leemelone
It doesn't matter what you setting you choose. It keeps moving around no matter what.
Old May 4, 2011 | 07:24 PM
leemelone's Avatar
leemelone
My experience with other vehicles is that a vacuum leak with cause it to default to the defroster and stay there. This always starts there but keeps moving around. It doesn't matter if it's at idle or if you're at a higher rpm. I've already inspected the plastic vacuum line you're talking about as much as I can without removing the entire thing and I don't see any obvious damage.
Old May 4, 2011 | 10:17 PM
dmarkshark's Avatar
dmarkshark
When you run the car can you feel the vacuum on the main line? The usual break on the line is in the engine bay area. The line runs from the back of the manifold down (I believe) by the bottom of the battery area , but I would make sure that the vacuum is holding on the main line, and if not you can follow the line back to the engine. I know when I pulled my line (under the dash), even after sitting for a while, I could hear the vacuum air releasing when I pulled the line off the selonoid. Pull the line off and see if you have vacuum.
To A/C Air Flow Keeps Moving
