Same problem, different gear
Old Apr 19, 2002 | 05:10 PM
KeithH's Avatar
KeithH
Default Same problem, different gear
Previously had a problem with difficulty getting into 1st gear. The dealer rebuilt the clutch and tranny replacing 1st, 2nd, 5th, and reverse. Got the car back and no more problems with 1st, shifts smooth in all gears except..... now, it doesn't want to go into reverse. Put it in neutral, engage the clutch, disengage the clutch, repeat the process numerous times, hold your mouth the right way and when it feels the time is right, it slides into reverse like there is no problem at all. Any ideas other than don't park anywhere that requires me to back out? Any one know a good exorcist cause I think this thing's possessed.
Old Apr 19, 2002 | 07:11 PM
te51cle's Avatar
te51cle
Default Re: Same problem, different gear (KeithH)
When the dealer was putting everything back together did they get the reverse gear lockout mechanism in correctly ?
Old Apr 19, 2002 | 09:31 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Back to the dealer!
To Same problem, different gear
