T-signal problem
Old May 4, 2011 | 02:54 PM
barblarry93's Avatar
barblarry93
Default T-signal problem
Found this on a different site to by-pass turn signal flasher on C5. It cost $6 versus $70 for bypass cable. It took 10 minutes, works great, no codes. http://www.ls1tech.com/forums/appear...er-bypass.html
Old May 4, 2011 | 09:07 PM
lionelhutz's Avatar
lionelhutz
If you leave the pink wire connected then the 4-ways or hazards will still work too.
Peter
Old May 5, 2011 | 07:00 AM
barblarry93
With the pink wire cut and hookedup as the directions, the hazards work anyway.
To T-signal problem
