Rear Fascia Removal
Old May 5, 2011 | 05:52 PM
White Rabbit's Avatar
White Rabbit
Default Rear Fascia Removal
i got all the screw/bolts in the door jam and both rear inner fenders out and all screws in the hatch. i found 4 plastic push pin looking things and 2 mounting points behind the license plate.. i break stuff constantly and dont want to ruin anything.. how do i remove all the plastic mounting hardware?
Old May 6, 2011 | 02:52 PM
jirasvet's Avatar
jirasvet
Not understanding why you are in the door jambs if just removing the rear bumper cover
Use a flat type screw drive or pliers to grab the
center of the push pin, should be a slot to pry out center of pin or grab the center with pliers and pull it out
2 Plastic screws
Old May 6, 2011 | 02:53 PM
CHJ In Virginia's Avatar
CHJ In Virginia
The two large ones in the license plate mount are screw in. Take a flat blade screw driver of the appropriate size in the square hole and just unscrew them. The other four plastic push pins are easy to remove. Just slide a small flat blade screw driver under them and pry up till you can grab them with pliers to pull them the rest of the way out. You won't break them !
Old May 6, 2011 | 05:44 PM
White Rabbit
i took the fenders and everything off "Going wide body" and the only points that were still holding were the rear bumper locations.. i took all the pieces off in one section..
Thanks for everybodys help
To Rear Fascia Removal
