Help!!!Column Lock
Old Apr 19, 2002 | 08:56 PM
tnkrenfro's Avatar
tnkrenfro
Default Help!!!Column Lock
What can I do to unlock the column wheel lock?...I am at work, the dealership is closed and I can't get it towed.
Please help!!!
Thank You
Old Apr 19, 2002 | 10:47 PM
yellowy2kc5's Avatar
yellowy2kc5
Default Re: Help!!!Column Lock (tnkrenfro)
This is probably too late since it's now 9pm and I just saw the post, but try starting the car, then turning the ignition off then on again VERY quickly, quickly enough that the engine doesn't even have a chance to die. Worked for me before.
Old Apr 20, 2002 | 02:58 PM
luvinc5's Avatar
luvinc5
Default Re: Help!!!Column Lock (yellowy2kc5)
The other way is to get one of the column lock bypass kits. Mine came with instructions on how to unlock the steering wheel if you were a victim.
GM has a recall notice to replace the column lock on certain years of the C5. Talk to your dealer....it may be a free service fix.
[Modified by luvinc5, 2:00 PM 4/20/2002]
Old Apr 20, 2002 | 03:04 PM
GoF4st's Avatar
GoF4st
St. Jude Donor '03-'06-'07-'08
Same thing happened to me check out my most recent post on this board I think. I will post a follow up b/c I was charged up the kazoo for something to do with it.
I dont want to really post another one at the moment unless someone cannot answer it but I was told this is not a recall. Something that is not my problem and screws me over should be a recall. I need more insight.
[Modified by JeffsVette, 7:08 PM 4/20/2002]
To Help!!!Column Lock
