c0200 fuel injector codes driving me nuts
Old May 8, 2011 | 03:23 PM
fsuforever's Avatar
fsuforever
Default c0200 fuel injector codes driving me nuts
Ok ,so I'm needing some help with this problem,I've checked resistance in all injectors & there all showing 13/good,last week I blew fuse # 22 & put. Another 1 in & its been doing fine up to this point,now there's a miss going on when there's a load on the motor,anybody have any experince with this before? I appreciate all thehelp I can get,btw I did a search to no avail
Old May 8, 2011 | 03:53 PM
fsuforever's Avatar
fsuforever
Update; just unhooked pcm & changed out fuse 22 eventhough it wasn't showing bad& now the dic states no codes,so I dunno wtf is going on with it
Old May 9, 2011 | 12:41 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
You'll need to get a meter out with the PCM unplugged, meter each injector wire, looking for low resistance to ground. I'm sure you have a chaffed harness behind the cylinder head somewhere since that's the most common cause of this problem. If it doesn't show up, try wiggling the harness while metering each injector wire.
To c0200 fuel injector codes driving me nuts
