ABS lights ??
Old May 9, 2011 | 11:26 PM
derekguzz's Avatar
derekguzz
Default ABS lights ??
my old man said the 99vert auto 100k miles had the ABS light, trac system ect lights come on today for about 3 miles then go off. I have had them go on before as well. Out of 50k miles we have had it, it might have hapend 5 times...Any hints?
Old May 9, 2011 | 11:30 PM
lucky131969's Avatar
lucky131969
post your codes
Old May 9, 2011 | 11:44 PM
derekguzz's Avatar
derekguzz
Well would the system give codes if the light went off? He said the abs light and trac system flashed in the digital area then went off. There are no lights ( ABS or check engine) on right now.
Has anyone ran into this before?
Old May 9, 2011 | 11:55 PM
derekguzz's Avatar
derekguzz
Well i used the search function for the first time in 4 years and found out its not a big problem. Either wheels spun on rough road/ rail road ect or loose speed sensor at wheels. Will check it out ..
Old May 10, 2011 | 10:15 AM
lucky131969
You're right....checking the codes is a waste of time.
Old May 10, 2011 | 03:25 PM
sjbrothers's Avatar
sjbrothers
There are a lot of post's on this subject and a 99 with 100K is probably due to a clogged BPMV pump. This pump gets tested everytime you start up and if it does not run correctly the code gets posted telling you to service the unit. Pull the codes and search the forum.
Old May 10, 2011 | 07:08 PM
derekguzz's Avatar
derekguzz
I don't mean to come off rude but you guys did read I have no codes right? The check engine light came on, then abs, trac lights came on all at the same time. They went off 3 miles later. I checked and have no codes.
Thanks for anyones help
Old May 10, 2011 | 08:51 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Sometimes you don't get any codes, but most times you do. It could be a loose ground, sensor, etc...
Sometimes you have to shake some of the harnesses with the car on to see if it throws a code, etc .... which will lead you you to the problem.
Old May 10, 2011 | 09:39 PM
byronhunter's Avatar
byronhunter
If the Check Engine light came on, you DO have trouble code set in memory. So why don't you pull the codes and post them.
Old May 10, 2011 | 10:04 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
The IPC display, the 20-character, vacuum florescent screen above the steering column that says "Corvette by Chevrolet" every time you turn on the key, is a powerful device. DIY Service Techs are going to be most interested in the IPC's ability to show diagnostic trouble codes (DTC) for all the modules that transmit them.
The "diagnostic display" mode is entered with the following procedure:
1. Turn on the ignition but don't start the engine.
2. Press the "reset" button to turn off any warning messages
3. Press and hold "options" and
4. While holding "options", press "fuel" four times within a 10-second period.
Inititially, the on-board diagnostics go into the "automatic" mode which shows each module's DTCs in a pre-set sequence:
Old May 10, 2011 | 10:09 PM
derekguzz's Avatar
derekguzz
thanks for the info. I will hook up the scanner again and see if I can grab a code or two. Thanks again
Old May 10, 2011 | 10:16 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You don't need a scanner, it's built into every C5. See above post for details on how to use the DIC (Drivers Information Center)
Old May 11, 2011 | 10:05 AM
dougbfresh's Avatar
dougbfresh
Generic scanners won't show these codes-use your DIC!
To ABS lights ??
