....was just thinking. You do realize that the pump will only run for two seconds ...when the key is turned to on.....right?
Yup, I do know that. You have been a HUGE help. Cant thank you enough. I have no problem with motor swaps, but I hate electrical stuff. I will do as you said with the relay and see if it works. Hopefully it is just a bad relay.
