Pop noise
Old May 13, 2011 | 09:40 PM
leomanger's Avatar
leomanger
4th Gear
Default Pop noise
My new challege, is a pop noise from right rear area? Could be the rear wheel assembly. I am but familiar with the assemblies. So, very time I start moving forward I hear a pop, shifting up I hear it again, same as is I like off the thottle I get the same pop or pop-pop. U joint?? A shaft with a key that is sloppy?? anyone / ideas??
Old May 15, 2011 | 01:17 PM
jake2000's Avatar
jake2000
Check the connections on the end links of your sway bar to make sure they are tight. That's what cause a "pop" for me.
Old May 15, 2011 | 04:50 PM
TEXHAWK0's Avatar
TEXHAWK0
Probably rust buid up in the spline and area where the CV hub tightens against the back of the bearing housing. You need to check the axle nut to make sure it is tight first. If it is, you need to remove the nut, push the axle in, and lubricate the inboard end of the splines.
There are posts with pictures on this if you search.
http://forums.corvetteforum.com/c5-t...earings-2.html
Old May 15, 2011 | 10:17 PM
tremor1's Avatar
tremor1
I had the same noise and this procedure fixed it.
To Pop noise
