transmission cooler with fan
Old May 15, 2011 | 03:20 PM
95TAMaddog's Avatar
95TAMaddog
Default transmission cooler with fan
I am installing a tranny cooler with a fan. I was wondering where you guys pulled your 12 volts from for the fan. Thanks
Old May 15, 2011 | 03:40 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I pulled the power off the secondary fan + wire--You can take if off either fan-ALSO--- many people bypass the radiator trans cooler--While you have to replumb you tranny lines anyway it makes it an easier install-Running it bypassed----This LOWERED my tranny temps about 10*
The radiator temps run up to 200-210* very quickly so you are trying to cool your trans with 200* water temps !!!! Not gonna happen-
I believe GM does this to actually WARM up the fluid in freezing or very cold areas--But if you use common sense in cold climates by letting the car warmup thoroughly before driving it is an easy way to add some trans cooling--
Old Jun 19, 2011 | 04:16 PM
TwoValveKid's Avatar
TwoValveKid
Thread hijack...im doing the same thing and will be bypassing the factory cooler...what are the fittings that connect to the radiator? Ive been looking all over and cant find em.
To transmission cooler with fan
