A4 Help
Old May 15, 2011 | 08:18 PM
77BlueL82's Avatar
77BlueL82
Default A4 Help
Had P1870 code. Slow shifting 3-4, hard 1-2. Chanced out the valve body and pressure plate. Now I still have the slow 3-4 and no reverse when tranny is hot. No codes.
Since the valve body doesn't control the reveres, what is happrning?
Any thoughts? Thanks in advance.
BTW I double and triple checked the torque on all the bolts and sequence two to three times.
Old May 16, 2011 | 09:30 AM
77BlueL82's Avatar
77BlueL82
ttt
Old May 16, 2011 | 11:19 AM
soggysailor's Avatar
soggysailor
Have you had the TCC valve in the valve body replaced? If not that could solve those issues. Its a kit that replaces a weak design by reaming a larger opening and using a new larger piston/valve. Most trans shops can R/R this for you without removing anything but the pan and valve body.
Old May 16, 2011 | 12:09 PM
77BlueL82's Avatar
77BlueL82
The new vb had that mod
Old May 16, 2011 | 04:49 PM
Bluefire's Avatar
Bluefire
Recheck fluid level. It is VERY IMPORTANT to check the fluid level when the fluid is between ~86 deg, F - 122 Deg. F. (per GM spec.)
I had a slight slipping after a H/C install. I checked the Trans fluid @ 180 deg., it was full. I let it cool to the proper temp ~100 deg. and I was 22 oz. low!!!!
Old May 16, 2011 | 05:04 PM
77BlueL82's Avatar
77BlueL82
Thanks. When the weather breaks I'll check again.
To A4 Help
