A/C Climate Control Problem
Old Apr 21, 2002 | 12:39 AM
luvinc5's Avatar
luvinc5
Default A/C Climate Control Problem
The problem is the passenger **** doesn't work but the rest of the auto climate control system is fine (ie. no problem cooling or heating). Anyone else with the same problem and if so, what is the fix?
Old Apr 22, 2002 | 09:17 AM
luvinc5's Avatar
luvinc5
Default Re: A/C Climate Control Problem (luvinc5)
ttt
Old Apr 22, 2002 | 09:41 AM
JMon's Avatar
JMon
Cruise-In III Veteran
Hmmm in what way doesn't it work?
You mean adjusting the passanger offset doesn't seem to change the pasanger side temperature?
Did it once work?
Old Apr 22, 2002 | 09:06 PM
luvinc5's Avatar
luvinc5
Default Re: A/C Climate Control Problem (JMon)
The passenger **** on the climate control, when turned in either direction, does nothing. It should be able to set the temperature for the passenger area differently from the driver's side.
To A/C Climate Control Problem
