Can't get into first gear easily... help
Old May 16, 2011 | 11:52 PM
Z06ster's Avatar
Z06ster
Default Can't get into first gear easily... help
I have an '02Z with about 56K on the clock. About a week ago, I started noticing that it is getting difficult to get into first gear. In fact, this evening, getting into first gear had a grinding of gears feeling. Getting into the other gears is fine. In fact, if I first go into second, it seems easier to get into first. I have had an aftermarket Hurst short shifter for 4+ years with no issues.
Can any one tell me the problem? Thanks
Old May 17, 2011 | 10:51 AM
badass85ta's Avatar
badass85ta
change the fluid you never know. could be a synchro or shift fork too or maybe the shifter needs aligned
