Time to live up to the name!
Old May 24, 2011 | 06:21 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
You're going to spend far more than $6,700 on a motor and a Twin Turbo kit. IMO, I don't think you are being very realistic.
Old May 24, 2011 | 07:58 PM
TriplBlk's Avatar
TriplBlk
Sorry man, really not a pro at this
I should have said that the motor wouldnt be fully dressed. basically a forged shortblock plus UPP's twin turbo kit for 5k.
LS2 block (Bored .30 over0 - $900
TSP LS2 402 forged stroker kit-$1900
UPP's TT kit- $5k
~$7800
Sorry for the ignorance though guys, kinda why I started this thread lol
Old May 24, 2011 | 08:52 PM
PEERPSI's Avatar
PEERPSI
Before you spend thousands consider spending $28 and read Maximum Boost. Once you have read it and understand it you will realize that a well thought out system would be better laid out then the one you are referring too.
Google TTI turbo systems for a look at a nice system.
For your goal and the budget you mention twin turbo or supercharger is the way to go.
Raising the redline might well lead to other needs like different gear ratios and more expense.
Old May 24, 2011 | 11:43 PM
lionelhutz's Avatar
lionelhutz
Add
cam - $500
pushrods - $300
roller lifters - $750
roller rockers - $800
prepped heads - $2500
oil pump - $150
gaskets - $200
bearings - $200
etc, etc
The stroker kit and a bored block are not even close to most of your expenses to build the engine you're talking about. Especially if you expect to get to 8k rpm on that kind of budget.
When I said you couldn't build an 8k rpm engine for $6800 I meant you couldn't build the engine only which doesn't include the turbo kit.
Peter
Old May 25, 2011 | 09:36 AM
TriplBlk's Avatar
TriplBlk
Ill see if I can find it.So I take it you mean to not use the UPP kit? but go for one like TTI? Ive heard of them before and seen some of the power they make. I am also not a "turbo junkie". I almost went with an STS kit cause the price was too good. Im not too picky, and the UPP seems very very simple which makes me a lot more comfortable as I will be installing this myself.
Originally Posted by lionelhutz
Add
cam - $500
pushrods - $300
oil pump - $150
gaskets - $200
bearings - $200
etc, etc
Peter
Thanks for the parts layout Peter. I know Iwould have to put more into the engine but sadly this wouldnt be one of those builds you see when the guys take a couple weeks and then have a completely assembled engine. This was kinda going to be a slow process build, by piecing it all together throughout the year and then later putting it all in.
You guys have convinced me that an 8k rev limit isnt possible and safe so Ill turn that idea down.
Im at the point now where I think Ill just buy the block, and the UPP kit. Block is $900(Seems like such a good price) and Id like to get the UPP kit before it magically goes up.
this way Im Only at $5900 and maybe some other things will fall into place.
Old May 25, 2011 | 09:43 AM
PEERPSI's Avatar
PEERPSI
When it comes to money you should always be picky.
Simple installation? It installs under the front fenders from what I can see. How is that simple?
Turbo's are driven but the hot expanding exhaust gases. If you mount the turbo several feet away from where the gas exits the engine the temperature drops significantly thereby defeating their purpose.
If simplicity is your gig, go supercharger. Inexpensive, easy to install and meets or exceeds your power goals. Don't cheap out and skip the intercooler.
Corky's book is available directly from Bell Engineering or more conveniently through the big online book retailers who I'm likely not allowed to mention here for fear of an illegal vendor promotion.
Old May 25, 2011 | 09:47 AM
dougbfresh's Avatar
dougbfresh
Guess you never saw the rear mounted turbos from STS.
Old May 25, 2011 | 09:59 AM
TriplBlk's Avatar
TriplBlk
Ill search for the book thanks
And yes simplicity in the design itself. But ease of install doesnt bother me.A TT kit for 5k is just too good to be true haha. 582rwhp at 8 psi? A supercharger does sound nice if I can get it for a nice price. Id do centrifrugal only though.
Old May 25, 2011 | 10:27 AM
dougbfresh's Avatar
dougbfresh
MAN, your all over the place on this-1st you want it to sping 8K, then you want HP, then you want to spend almost nothing to do it. Think it's time for a reality check HAHA (as you like to say).
Old May 25, 2011 | 11:29 AM
TriplBlk's Avatar
TriplBlk
LolYou always crack me up
I have ADHD and Im extremely impulsive. BUT I cant fight the fact of what you all tell me about revving to 8k. I mean hearing it from many people that it cant be done with this budget, well, then Im going to agree and accept it haha. Right?
$6,700 is me wanting spending almost nothing? Doug, I need your kinda paychecks then dude .
Do you mean the fact I wanna spend only 5k for a TT kit cause its so cheap? Well yea its affordable and IMO a nice setup and will be a good benchmark to start for power.
Old May 25, 2011 | 11:40 AM
PEERPSI's Avatar
PEERPSI
I have and I'll refrain from comment for fear of offending or getting sucked in.
Old May 25, 2011 | 11:43 AM
PEERPSI's Avatar
PEERPSI
Why only centrifugal?
http://www.eaton.com/EatonCom/Produc.../TVS/index.htm
76% efficiency!
Too bad Edlebrock doesn't make the Vette kit for C5's. Now you could put in a C6 engine with their kit on it.
Hmm, where did I leave my cheque book.........
Old May 25, 2011 | 11:56 AM
  #33
TriplBlk's Avatar
TriplBlk
76% efficiency!
lol cause I have a Harrop, Ill probably get ripped on for this but I like being different Im going to boost the Harrop.
Old May 25, 2011 | 02:49 PM
  #34
dougbfresh's Avatar
dougbfresh
A standard twin turbo setup under the hood will cost you a lot more that $5K to do it right. The STS is easier since your not forced into an intercooler till you get to higher boost and the underhood temps are much easier to deal with too.
Old May 25, 2011 | 03:07 PM
  #35
lucky131969's Avatar
lucky131969
.........Im going to boost the Harrop.
Good luck with that.............
Old May 25, 2011 | 03:31 PM
  #36
4SFED Z's Avatar
4SFED Z
Add
cam - $500
pushrods - $300
oil pump - $150
gaskets - $200
bearings - $200
etc, etc
Peter
dont forget labor and tune as well. To have it done right, more like 12g at least. Id say do the 383 and TT it.
Old May 25, 2011 | 04:39 PM
  #37
zeevette's Avatar
zeevette
What about the budget for the drivetrain? You're gonna need at least a DD clutch, and new DS bushings. Maybe beef up the output shafts, and don't forget a trans brace, etc. to support all that power. Transmission won't take it, I could go on.....
To Time to live up to the name!
Old May 25, 2011 | 05:24 PM
  #38
dougbfresh's Avatar
dougbfresh
I want to see him spend his budget-should be "amusing" HAHA
Old May 25, 2011 | 08:33 PM
  #39
lionelhutz's Avatar
lionelhutz
Should really just stick a C6 (Z06 or ZR1??) trans and diff in it, will only run about $5k to $6k. The second time you blow the C5 diff you'll wish you'd spent this cash up front.
Peter
Old May 25, 2011 | 08:42 PM
  #40
schpenxel's Avatar
schpenxel
St. Jude Donor '15
My head is going to explode at what I'm reading in this thread. A 8k RPM motor for how much? Then you're told to ignore a well priced turbo kit that has put down over 800hp on c6 builds because of some book some guy read? I don't care if it's the most efficient system ever made and I doubt he does either. The guy's on a budget and it's a good option to consider.
Or I'd look into the SC option.. I know you want to use that crazy *** intake but it's going to be more trouble than it's worth.
