Thermostat Trouble
Old May 17, 2011 | 01:15 PM
aobrien14's Avatar
aobrien14
Default Thermostat Trouble
I have a '98 Auto Corvette LS1.
I'm intending to install a 160 degree thermostat, but am having a heck of a time finding one to fit. Both units that have been ordered through AutoZone (most recent being Hypertech Part No. 1014) do not fit into the inside diameter of the water pump opening for the tstat. The opening in the pump is 1-3/4" while the Hypertech needs a 2" opening. Can anyone direct me to the correct part?
Old May 17, 2011 | 02:02 PM
rboineau's Avatar
rboineau
Seems like I remember seeing on the Forum that earlier C5s used a different housing/thermostat diameter. Perhaps a check with a Chevy parts guy could confirm, 'tho if the above is right I'm surprised the parts stores aren't on top of it.
Old May 17, 2011 | 02:49 PM
aobrien14's Avatar
aobrien14
Mystery solved...original water pump was replaced by prior owner in 2008 and they must have installed an updated pump...new tstat on the way. Thanks.
Old May 17, 2011 | 03:07 PM
hornet7's Avatar
hornet7
Default T-stat
When I changed mine on my 98 coupe, the t-stat and housing was one assembly. All was good. Are you sure you have the correct unit?
Old May 17, 2011 | 03:10 PM
hornet7's Avatar
hornet7
Default T-Stat
Just seen your last post.....Never mind!
Old May 19, 2011 | 04:37 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
yep..had the same issue
Old May 19, 2011 | 06:26 PM
moserbe's Avatar
moserbe
Recently had the same issue. You will also need to replace the thermostat housing to the 2004 version.
To Thermostat Trouble
