It seems the way the end bleeder valve mounts to the brake booster may make it hard to get a wrench on to bleed when needed.
My mechanic suggested not mounting end and just wire tieing the end under the cowl so it would be easier to use when needed.
Any reason not to do this?
Anyone use their's yet and find it hard to use when mounted?
thanks
I was under the impression that the mount was there for holding the
end of the remote bleeder to make it easy to take out of it's mount & go about the bleed proceedure?
thanks
Don't tell TPE but I turned the mount around and mounted their bleeder to the inboard bolt on the booster and that makes it really easy to get a wrench on.
Add in a line lock in the same space and its impossible to use.I axed the mount and zip tied it up out of the way.Much easier,perhaps not as tidy as the nice mount jeff provided but usable.
