2004 need to know the easyist way to change it or is there a thread on it
Fuel tank needs to be dropped out of the car. I had my '04 vert pump replaced under warranty. It kept blowing fuses after heating up.The dealer charged 1890.00 to do it. 0.00 to me.
Are you certain it is the fuel pump and NOT relays or fuses????
Have you verified fuel pressure yet?
This.
Dealership told me my pump went out and wanted $1200 to replace it. No way in hell I was going to pay that much for a $300 part, so I did it myself. Still didnt work. Turned out it was a bad ground to the relay. Piece of wire later, never had a problem with it again (well, until the computer decided it didn't want to control it anymore...)
There is still a pothole in the parking lot where the gas overspilled
havent done nothing yet trying to find out thing to check drove it to work filled up drove home pulled it in my shop got up next to go to work and wouldnt start
fuel psi ok
it was the crank sensor everything else ok 260.00$ later
got a old chevy line mech done it 4me i work 65hrs aweek
dont havetime or energy
thanks for all the help friends
