Horn changed tone - Am I nuts?
Old May 21, 2011 | 08:23 PM
Chief777's Avatar
Chief777
St. Jude Donor '15
Default Horn changed tone - Am I nuts?
My horn has been acting up recently. Going off at random times and it blew the fuse. So I just replaced the pressure pad. It works now, but, I swear the tone had changed. It sound higher pitched and doesnt seem as loud. Am I going nuts or is there something else I should check?
Thanks!
Old May 21, 2011 | 11:07 PM
bigleman's Avatar
bigleman
Yeah, check the horns up front.
You can get to them from under the car or remove the passenger headlight assembly (2 bolts, 3 nuts) to go in from the top.
Old May 22, 2011 | 02:15 PM
cruisemon's Avatar
cruisemon
Did you have an argument with a curb or pull into a parking place and bottom out the lower radiator support recently? Hit one hard enough and it will damage/destroy one of the horns. It can also damage/destroy the steering wheel position sensor and set C1211 code. Do it hard enough and you're looking at $3,000 plus to repair it.
Charlie
Old May 23, 2011 | 11:52 AM
Chief777's Avatar
Chief777
St. Jude Donor '15
Originally Posted by 8VETTE7
There are actually 2 horns connected together, one hi tone and one lo tone. One may have blown. Happened to one of mine due to water getting into the horn. Located on the passenger side just under the front bumper. A small plastic cover goes over the location presumeably to limit the water that can et to the horns????
Thanks! I dont think any water got in there, but I'll take a look adn see which one is blown. Oh and apparently I'm tone deaf. My wife insists it sounds lower.
Charlie
Yikes, thankfully that didn't happen!
To Horn changed tone - Am I nuts?
