The car makes over 900RWHP and today in second gear sudenly the car shut off and after checking everything is the timing change broken!
The question I need to know are:
1 Normally LPE put stock chain or heavy duty one?
2 If it is heavy duty, where to buy or which are the best for high HP car?
3 Why they broke?
4 Do you also think I will have bent valves issue?
I broke a timing belt on a Supra several years ago and just replaced and NO problem, I'm crossing my fingers also on the C5.
You're gonna have to tear the top-end down to assess the damage. Man, that's alot of horsies, and things are going to break at your power level. Good luck.
