Rear end removal
Old May 22, 2011 | 07:02 PM
Derald's Avatar
Derald
Default Rear end removal
How do you remove the differential, Thanks, Derald
Old May 22, 2011 | 07:06 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
There are many writeups about removing the transmission and clutch. Same procedure except not as far into it.
Old May 22, 2011 | 07:10 PM
craig04c5's Avatar
craig04c5
You have to drop the rear cradle with the suspension still attached to the cradle. Do a search to find out the procedure. I was with England Green when he put my 4:10's in and while it is a lot of stuff to disconnect it only took him about 5 hours start to finish but he had done a bunch before that and has a lot of experience. I would say it would take someone unfamiliar 8 hours or so. Also remember to watch as the engine tilts to not crack your firewall.
Old May 22, 2011 | 08:58 PM
bumble-z's Avatar
bumble-z
Pm sent.
To Rear end removal
