Fluid Check A4
Old May 23, 2011 | 03:22 PM
77BlueL82's Avatar
77BlueL82
Default Fluid Check A4
Can the fluid in an 4l60 be checked park instead of neutral as the procedure states?
Old May 24, 2011 | 01:09 PM
corvettebob1's Avatar
corvettebob1
Yes the only difference is in park there is a parking pawl engaged.
Old May 24, 2011 | 03:23 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Either park or neutral is fine. The fluid level will be the same.
Old May 24, 2011 | 04:15 PM
Bluefire's Avatar
Bluefire
FYI, The temp of the fluid you are checking is very important. SM states that the fluid temp must be between 86F - 122F when checking it's level.
How do I know?.... mine was full @ 180F. It was 22 oz. low at the proper temp.
Old May 24, 2011 | 05:55 PM
Quicksilver Vert 01
Good point!
I always try to check the fluid at 104 degrees, which is the midpoint of the above temps.
To Fluid Check A4
