C5 automatic transmission question
Old May 23, 2011 | 08:48 PM
XXXC5's Avatar
XXXC5
Default C5 automatic transmission question
Does anyone have a picture of this component actually bolted properly to their car or what the bracket looks like that holds it to the car?
This is right behind the rear diff.
Thank you
XXXC5
Old May 23, 2011 | 11:22 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
That's not your transmission, it's your ABS brake Module.
Old May 24, 2011 | 07:45 AM
XXXC5's Avatar
XXXC5
I know it wasnt the transmission, I was just stateing the car was an automatic since I didn't see this part on the manual transmission car I had in the garage.
Anyone have a picture where the bracket goes on this module so I can put it back where it belongs? Someone just had it wire tied to the rear sway bar.
Old May 24, 2011 | 09:06 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Your car must be a 1997 or an early 1998 vette. It doesn't matter whether it was an automatic or manual transmission. It's about the production period.
Contact Gene @ http://www.gmpartshouse.com/
Have your VIN# ready when you call Gene and he can help you out.
Old May 24, 2011 | 09:44 AM
XXXC5's Avatar
XXXC5
yes,its an early C5,Thanks, I'll give him a call.
Old May 24, 2011 | 10:14 AM
melvingregory's Avatar
melvingregory
I can get a couple pictures this afternoon after work to show the brackets. Something doesn't look right about the rear cradle. During the 1998 model year, just prior to production of cars with the Active Handling option, the Corvette's ABS brake hydraulic control unit was relocated to the front of the engine compartment to facilitate quicker Active Handling system "warm-up" and shorten front brake response time when the brake fluid is cold. In temperatures below 14oF, the Corvette's Driver Information Center (DIC) will display an "Active Handling Warming Up" message as soon as the vehicle reaches 6-mph. That's a caution to the driver that Active Handling is not fully-functional yet. As soon as the system warms up, another message "Active Handling Warmed Up" will be sent to the driver via the DIC
Old May 24, 2011 | 12:24 PM
TheWildcat's Avatar
TheWildcat
looks like the rear cradle has been replaced with a later model one/ I have a set of brackets but you will have to drill 6 holes for the bolts..Let me know..John
Old May 24, 2011 | 12:49 PM
melvingregory
I agee.. here are some pictures of my 98 rear cradle. There is a indent where the brackets go, but drilling and mounting the brackets shouldn't cause any issues.. tied to the sway bar... that's so not right!
Old May 24, 2011 | 03:47 PM
XXXC5's Avatar
XXXC5
Thanks guys! this was what i wanted to know. thank you for taking the time to get some pictures up for me to see what it should look like.
John-i'll let you know about the brackets when i talk to the owner.
To C5 automatic transmission question
